This is to give +6db output compared to typical 2x woofer h-frame dipole setup, while keeping the system reasonably small.
Depth should be kept between 30-40cm to give useful output 120Hz and below. ![]() Any comments ?
http://gainphile.blogspot.com |
#2 |
Looks like a doubled-up W-frame. Not that there's anything wrong with that, but the drivers should have a fairly stiff suspension to be able to play in that orientation, and you probably want to rotate them every 6 months (arbitrary number) or so.
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#3 |
Yes it is. I've been thinking of stacked w-frame, but did not like the width. With this configuration the front baffle is kept narrow at around 30cm with 10" woofers.
Are you talking about driver suspension sag? is this a problem?
#4 |
frugal-phile(tm)
6dB?
4x vrs 2x gives 3 dB more efficiency and maybe more available power depending on how they are wired, This is a concept i came up a long while ago.... ![]() Push-Push Dipole Concept This keeps the drivers oriented in a way that gravity doesn't drag them down. I'd at least reorient things so that the drivers are firing sideways. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 | |
yes, according to SL
#6 |
frugal-phile(tm)
Note that 3 dB of that "then twice the electrical power is consumed (+3 dB)" is from doubling the power delivered by assuming a constant voltgae source, so in your situation, you have 16 ohm woofers and are wiring for 4 ohms and you amplifier is capable of doubling power into 4 ohms.
The more likely situation is that you have 8 ohm woofers, and you'll be series/parallel, which (given a constant V amp) nets you 0 dB (but 3 dB more efficiency) dave
#7 |
Some of you guys must have very large listening rooms! I've got more than enough bass with single 15 inch woofers (Hawthorne Augies) per channel.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#8 |
Very good idea
I just rotate the twin W dipole sub in order to have the higher sub ouput in front of the baffle. |
#9 | |
John k.... Music and Design NaO Dipole Loudspeakers. |
#10 |
When I did something similar, I used a second set of amps to get +3dB, instead of wiring them all series-parallel. Not sure if it is worth it though...
Something to consider is the distortion profile of your drivers - you probably want more output lower in frequency, but the two cases I've looked at, at the low end of the dipole woofer's passband, distortion rises rapidly. So high, that more drivers wouldn't help. These are high qts drivers, maybe low qts with low fs values (<25Hz) wouldn't have this problem?
double complete rainbow all the way!! |
| DIY: Dipole 8" array with Neo 130cm Ribbon | Bent | Planars & Exotics | 28 | 6th October 2009 07:44 PM |
| Dipole Ribbon tweeter isolation from dipole mid-woofer array | Bent | Planars & Exotics | 5 | 21st May 2009 12:10 PM |
| Good for a dipole midbass array? | Fast1one | Multi-Way | 5 | 18th August 2008 07:34 AM |
| Dipole array | bhg41088 | Multi-Way | 0 | 21st July 2004 12:20 AM |
| line array? dipole? | Shpoop | Multi-Way | 4 | 19th July 2004 12:18 PM |
| Page generated in 0.11365 seconds (78.90% PHP - 21.10% MySQL) with 11 queries |
