Especially in tribute to Mr. Fitzpatrick; I confess to not understanding bi-wiring when using an outboard crossover. Should the bi-wires go from amp to crossover or crossover to separate speaker inputs or both? Thank You for your time. Gary Hubbard.
#2 |
if the crossover is mounted directly on the output terminals of the amplifier then you have eliminated half the problem, where to put the cables between amp and crossover.
As for the cables from crossover to speaker. Solder a direct wire connection from each speaker driver input terminal back to the appropriate output terminal of the crossover.
regards Andrew T. |
| Sub Wiring | BEAN27 | Subwoofers | 19 | 6th May 2006 04:14 AM |
| Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... | thomgun_lc | Chip Amps | 38 | 31st August 2005 02:46 PM |
| I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) | Audiophilenoob | Chip Amps | 9 | 16th August 2005 04:37 AM |
| bi-wiring | Dave Jones | Multi-Way | 13 | 27th November 2004 05:41 PM |
| Page generated in 0.06550 seconds (66.94% PHP - 33.06% MySQL) with 10 queries |
