Thielle Small Parameters:
Power max. 500W Power rms 250W Overall depth 100mm Maget diameter 140mm Mounting centres 194mm Diameter 20cm (8") Frequency response 27Hz - 6kHz Magnet weight 1.1kg (40oz) SPL @ 1W/1m 91dB Re 7.0 Ohms Fs 38 Hz Qms 7.1 Qes 0.51 Qts 0.54 Sd 218Cm2 Vas 22.6 litres Cms 336 Mms Hi can some one tell me if the spec of these drivers would be a good choice for a TL design |
#2 |
You should visit here and study Martin King's excellent work on modelling TL speakers.
Transmission Line Theory Also click on Webb's alignment spreadsheet and enter your driver's spec's. It will give you the TL length. You have to decide whether or not to taper it. Reading the theory will help you make that decision. If you're serious about building your first TL, then you'll do well to understand the fundamentals of it. Good luck. |
| STK Choice | metal | Chip Amps | 21 | 1st October 2010 03:48 AM |
| Need help with car sub and amp choice | sbrunkow | Car Audio | 14 | 14th December 2008 09:49 PM |
| Choice of DSP | Severance | Digital Line Level | 5 | 22nd October 2008 05:49 PM |
| Smd -VS- Pdip,which one is the best choice? | digi01 | Digital Source | 2 | 23rd May 2005 08:41 AM |
| Choice of a sub | elizard | Subwoofers | 4 | 13th December 2003 06:32 PM |
| Page generated in 0.05713 seconds (80.08% PHP - 19.92% MySQL) with 10 queries |
