hi all
i am building some speakers and i have a dilemma. my panels are veneered all around. when butt joining them, should i glue to veneer directly or should i remove a strip so that i glue mdf to mdf? |
#2 |
I'm guessing the veneer is actually vinyl, as most furniture board is? I know for sure the wood glue I use will not stick to any plastics or metals, that's EvoStick glue, some may be more tolerant. If it's real wood veneer it will stick, but it may compromise the integrity of the joint glueing to such a thin piece of material. Removing a strip to glue MDF to MDF is a sure way to get a good joint in this instance
#3 | |
I'd remove the vener just to be safe anyways. I'm sure an exacto knife would do the trick. |
#4 |
thanks for the advice guys
yes the veneer is oak wood but i will go ahead and remove a strip for a good joint thanks |
#5 |
by the way what the best way to treat exposed mdf in the corners and chamfers?
ideally i would like to use the same veneer but its a lot of work... |
| Gluing and Clamping | wintermute | Construction Tips | 6 | 25th August 2009 03:09 AM |
| Gluing questions | rbmcginnis | Planars & Exotics | 11 | 31st July 2006 05:06 PM |
| Gluing in T-nuts | DSP_Geek | Multi-Way | 13 | 20th November 2005 07:08 PM |
| Wet gluing veneer | tiroth | Multi-Way | 11 | 22nd October 2004 07:12 PM |
| Page generated in 0.07748 seconds (73.64% PHP - 26.36% MySQL) with 11 queries |
