#11 |
YES
NP caps
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#12 |
Cool. The "No" was really a consensus from what I searched. Only one place said "yes" while the rest didn't say one way or another.
Does that mean that I have to use cheesy electrolytic caps or, do I have options here. Searching P.E. doesn't say on many of them. And thanks for setting that straight. |
#13 |
All film caps are non-polar. Most electrolytics are polar.
You want EITHER film caps (expensive for values higher than about 2uF) or bipolar electrolytics. - Chris |
#14 |
Except I would have said expensive for values higher than 10uF, Go with green-caps perhaps if the idea of better film caps hurts the wallet
#15 |
Depends where you're buying of course - at my local jaycar, it's hard to get film caps > 3.3uF without going to their polypropylene range, at about $2 a uF.
#16 |
If I read this right, these should be fine for low pass use, correct?
Jantzen CrossCaps are built from ultra-high-quality Finnish film and provide superb sonic accuracy and detail for any audio application. 400VDC rating is excellent for crossover networks, allowing the capacitors to flawlessly handle large current peaks without distortion. If not, can anyone suggest another? |
#17 |
I haven't bought greencaps in a while but Jaycar Thomastown had values to 12uF in stock, can't remember how much I paid though
#18 |
THUMP LUMP, PeteMcK,
I would like to build the jig, but I have some problem in correctly understanding the design. Are you so kind to share some photo of the jig? A PM is also fine. As for capacitors, if used in parallel for a woofer, you could also use a polyester one (150V), better than the electrolytics (they tend to vary in value over time), no need to use a more expensive polypropylene (400V). TIA, Ralf |
#19 |
#20 |
mmmmm.........I got to looking around in the various forums here and found this....DIY Chip Amplifier Kits, PCB's, Components and Information. over in the "Chip Amp" forum. Since the main reason for going to a passive crossover setup was to eliminate one of the two amps I am using now in a bi-amp setup with the speakers mentioned prior, it looks like I could build some of these and save alot of space and still keep the bi-amping.
I think I will looking into these kits some more and see if I am up to doing them. Meanwhile, I have gotten the MDF I need to build the proper size cabinets for the A/D/S woofers. Once I get the woofers and tweeters in the cabinets, I am going to get some Frequency Response measurements from them. Just see how well they work in the box, independently and together. |
| Page generated in 0.10535 seconds (80.51% PHP - 19.49% MySQL) with 9 queries |
