Old 8th November 2009, 04:23 PM   #1
K-amps is offline K-amps  United States
K-amps's Avatar
Default Need help... will pay for small service.
Guys.. I need help.
I made my DIY speakers and need help determining the frequency response. I am willing to donate $25 to you or to DIYaudio if anyone can send me a simulated frequency response (graph from 250Hz to 40kHz on db scale) for my mids and highs. Also impedence plots if possible
My speaker is a mutli-amped multi driver system. (see attached schema for mids/highs)
Low's 4x TB 740 8" woofers
Mids 2x Vifa P13's
Tweets 2x Vifa XT25's (4 ohm)
Super Tweet 1x XT25
The mids/tweets/STweet is powered by the same amp, The woofer and subwoofer, have separate power amps.
I have a have tuned the speakers purely by ear. I am well aware of the pitfalls of doing so, hence my desire to see how far off I am from a flat response. I do expect dips and peaks... some of that I am willing to live with because of my own listening biases....
I would like someone to do a simulation of these drivers with these crossover values and let me know if a response can be simulated.
I know I need to reverse the polarity of the tweeters (2nd order), but if there are other improvements/ fixes you can suggest that would be great.
Also these are installed on an open baffle, and I forgot to label the polarity of the drivers, all are drawn so the positve (hot) terminal is up.
Thank you so much in advance!
Old 8th November 2009, 04:51 PM   #2
A simulation would be pure theory.
Suggest you invest in a low cost sound level meter. RS has them for about $50. Also get a test signal CD with 1/3 octave warble tones to play thru your speakers while you measure the response.
Old 8th November 2009, 05:02 PM   #3
R-Carpenter's Avatar
Send a message via ICQ to R-Carpenter
Better yet, buy a measurement microphone from parts express for $40 and use free software like Holmi Impuls or free version of ARTA to do a real FR measurements.
Old 8th November 2009, 06:01 PM   #5
Ron E is offline Ron E  United States
Ron E's Avatar
A RS SPL meter is not a precision instrument. You can get a FR measurement, but there is no assurance of reasonable accuracy. Taking FR measurements by writing down point using warble tones or pink noise is a royal PITA/ An extra $50 or ~$100 (~$150 calibrated) will get you a mic & preamp with which you can do actual design.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 8th November 2009, 09:42 PM   #6
K-amps's Avatar
Thank you all for your ideas.
Ron do you have any suggestions for a cheap and accurate mic + preamp. I think I already have a ECM8000.... came with my Behringer DSP-8024.
Can't anyone use the publisehd specs for the drivers and put them in some software and PRESTO!
Old 8th November 2009, 09:50 PM   #7
presto-smesto it's still only theory.
DO THE MEASUREMENTS. It's real world stuff!
Old 8th November 2009, 09:57 PM   #8
K-amps's Avatar
I tried once, they were so weird that I was left scratching my head. Also tried the DSP-8024's auto EQ function to simulate an inverse FR that was weird too.. adjecent frequency bands had 24-25db differences...
Old 8th November 2009, 10:49 PM   #9
Inductor's Avatar
You will receive a PhD at the end of this thread...
http://sub-source.com/tribute/images/rabbit_pancake.gif
Old 9th November 2009, 12:36 AM   #10
This is why I've suggested Holmi. It has automatic gating which is very useful for a beginner (in measurements)
You can't just plug manufacturer's FR and impedance in the crossover calculator and expect perfect results because the crossover will have a significant effect on the phase of each driver there for an overlap and the summed up frequency response. The baffle, it's size and the driver placement will affect FR of the loudspeaker as well. Baffle step loss comes to mind as well. Off axis response can make the loudspeaker sound great or bad in the room depending on the crossover. So, no. You can approximate the results in the crossover design software but the real world measurements and understanding is the key to a great sounding system.
If you have ECM 8000 already, all you need is a Behringer or other cheap mixer. Make sure it has phantom power supply for mic. ECM 8000 is probably the best or one of the best inexpensive measurement microphones. You can also have it calibrated for $50 if I am not mistaken.
small-signal (small-power) fast switching complementary transistors Lola Luna Solid State 3 8th April 2010 07:51 PM
Small-signal (or small power) pentode that can handle 400V (or more)? GordonW Tubes / Valves 12 13th June 2008 02:07 AM
Small parameters for a small free-air sub comjunky Car Audio 4 4th December 2007 03:45 PM
PC-speakers + small amp (key words: small, cheap) rho Multi-Way 8 18th May 2006 01:19 PM
Small case for small boards pcspinheiro Class D 11 4th November 2005 05:20 AM
Page generated in 0.13742 seconds (72.73% PHP - 27.27% MySQL) with 11 queries
