.. for the first time in many months !
http://members.optusnet.com.au/~gradds55/OB-1.JPG 1.2m tall, 1.5" thick Selenium D210TI on 6" wave guide Beyma 6Mi80 (hi-efficiency mid) 2 x 15" Etone PA drivers. if you look at the left one, you can see where I stuffed up and had to replace the section around the mid. forgot to check the router bit depth.. doh !! |
#2 |
just another
I bet the router was feeling warm after that
Tony. |
#3 |
#4 |
..." extra bass "... chuckle/snort! no, seriously they look great and maybe would make your ears bleed from a 1 watt amp? The Selenium and Beyma are still available?
#5 | |
I'll be using my PA amps because they all have graphic EQ built into their cabinets So, that's a Mackie M-1400, a Tapco J800, and a Behringer A500. I have a Behringer CX3400 to do the x-o work. Gunna be fun I hope that is enough power for a small lounge room The Beyma I got from in Sydney.. the Krix dealers iirc The Selenium I got from a MAdisound sale, at $25US each, about $47 each, landed. iirc |
#6 |
I think you are going to need some more grunt Andy, I hear you have a reallyy big lounge-room ( at least it would be if it wasn't full of projects ) I use the CX 3400 and it is adequate but a little noisy, are all the amp inputs balanced?
Jealous Ted
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#7 |
Hi Andy,
'Nice looking project - those big pro woofers look tasty! What sort of crossover points are you looking at? Jim |
#8 | |
so, yes, all connections up to the amps will be fully balanced.Lounge room is a 'nice' size. and its not 'that' full of loudspeakers.. methinks someone was exaggerating |
#9 |
Old Australian pastime then, exaggerate for emphasis, otherwise known as friendly **
#10 |
hey Andy,
are they 'done+dusted' yet? |
| Dust Extraction | sploo | The Lounge | 7 | 21st March 2007 05:08 PM |
| Dust Cap Replacement | Leoken | Subwoofers | 4 | 23rd August 2006 04:01 AM |
| Home Made Tubes?? has anyone made one, is it possible?? | John Biles | Tubes / Valves | 7 | 11th December 2005 01:29 AM |
| Dust + Speakers | Alex_B | Multi-Way | 3 | 18th December 2002 02:12 AM |
| Page generated in 0.10203 seconds (77.90% PHP - 22.10% MySQL) with 11 queries |
