Old 7th November 2009, 03:11 PM   #1
Default Speaker builders - I need your expertise
Hi all. I am thinking of doing something a little unconventional. I have a pair of Martin Logan Clarities and in my system/listening environment the bass and upper freq sound okay, but what is lacking a bit are adequate mids - say from around mid 300Hz to a little less than 1kHz. So I am toying with the idea of matching an external XO and high quality mid driver that doesn't need a complicated baffle/enclosure to make up for the softness in these frequencies. For experiementation purposes, I plan on making these completely external for now and then when I get things tweaked correctly, I am considerning permanently moutning them onto the MLs.
So expert panel - thoughts, suggestions, etc??? Thanks.
Old 7th November 2009, 03:33 PM   #2
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Change placement, perhaps?
Adding complexity like this doesn't seem like a good idea, especially with a different kind of driver...
Jim J.
Old 8th November 2009, 12:34 AM   #3
Andersonix's Avatar
XO on Clarity is 450Hz, so perhaps you can home in on whether you feel the mids are lacking from the mid-woofer or from the ESL section?
My guess is the 'mid-range' sounds good as long as you place yourself in the smallish sweet spot? (from which there is no escape, by-the-way...)
Old 8th November 2009, 07:01 PM   #4
Inductor's Avatar
Check in this other posts, maybe they can help a little.
Is there a "Martin Logan sound?" - diyAudio
ECM8000 gurus - need your expertise! smellygas Multi-Way 4 2nd March 2009 03:43 AM
Minnesota Speaker Builders Get together Zero Cool Multi-Way 1 22nd July 2007 06:15 PM
Any experienced speaker builders in Boston area? spwal Swap Meet 0 15th December 2006 05:51 PM
Technics 1210 MK2 Expertise wanted sikniks Analogue Source 17 6th July 2006 02:59 PM
strip mining expertise audio-kraut The Lounge 0 27th May 2005 07:15 AM
Page generated in 0.06038 seconds (81.74% PHP - 18.26% MySQL) with 10 queries
