#31 | |
This wire resistor is usualy used to match resistors better. When needed. |
#32 |
Jackinnj- Yeah, I've heard of that AP outfit, they probably use op-amps and software to get the answers- highly suspect methods ;-)
Still, no matter how trusted the equipment, I always like to do a reality check with physical artifacts. I've read about very flat response RF standard resistors that are basically sheet metal affairs, though I can't for the life of me figure out exactly how to build one from the diagrams and descriptions. They look sorta like a tapered stripline with a resistance wire bonded across. FWIW, I've tested various well known winding patterns and found that the "non-inductive" patterns don't buy as much as one might hope. The old Julie technique where they divide a bobbin into sections and change the direction on each section isn't very good, so my guess is that combining resistors in any special physical orientation doesn't accomplish much either. Still, whatever inductance there is doesn't seem to matter (to my ears). It does bother me that the percentage "tilt" over the audio range is as much as your graphs show, as I could imagine hearing that. CH
I used to be an audiophool like you but then I took an arrow to the knee. |
#33 |
if all power resistors are inductive, I as ask myself, do they interact if mounted close to each other
we know coils do that could this be any issue |
#34 |
Of course they will. The question is, does this interaction significantly affect the functioning of the circuit?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#35 |
tinitus, have you experienced the sound of inductor interaction? I found out by accident once. The values were large, connected to a woofer and at least one was iron cored. The sound was like electronic reverb, only less distinct...a little phasey if that's a word.
I cant imagine resistor inductive interaction (in a passive crossover) as having a significant enough effect to be a problem, or even audible. |
#36 |
yes, and just right now, actually
in the two schematics you will see different orientation of a small paralel coil on tweeter difference in sound is significant no doubt about it and phase issues are very clear too maybe a different size inductor would change that to the opposite but I have not tried, so I dont know funny thing is that Troels Gravesen suggest the opposite orientation now, all my power resistors measures about 0.025mH some bigger ones even twice of that considering that resistor inductance is about 10% of the coil, well.... but my thought was aimed at power amps where we often see multiple power resistors mounted very close to each other well, we are in speaker forum |
#37 | ||
Meh ... ![]() Quote:
Sounds good, make mine wire wound with silver leads.... |
| Where to buy Mills non inductive 5 watts resistors in Europe? | supernet | Swap Meet | 4 | 14th October 2006 04:35 PM |
| WTB: 1ohm 5 w Mills resistors | paulyang | Swap Meet | 3 | 8th December 2005 06:59 AM |
| Mills Resistors for Aleph-x for sale ! | promitheus | Group Buys | 1 | 5th August 2005 06:42 PM |
| Teflon wire and Tantalum resistors... | AudioFreak | Parts | 7 | 31st January 2002 02:08 PM |
| Page generated in 0.11439 seconds (82.60% PHP - 17.40% MySQL) with 11 queries |
