Closed Thread
Old 7th November 2009, 01:01 PM   #81
diyAudio Moderator Emeritus
Bas Horneman's Avatar
I've also been away for a time (approximately 4 years). Yes there are some threads which go on, and on, and on (like this one apparently is heading in the direction of). Yes there is the perpetual posting (from both sides) trying to convince the other side that they are wrong (faith based vs science based). IMO if it bothers you, tune out!! There is no point trying to convince someone of something that is not within their version of reality. By all means try if you must, but if it doesn't work give up already! (this goes for both sides of the fence).
Amen.
Old 7th November 2009, 01:02 PM   #82
I'm not sure why I get involved in these threads.... I think it is some sort of bizarre wish to try and mediate, and get people to be a little less black and white, but in the end I'm probably just adding to the noise
Amen again.
Old 7th November 2009, 01:05 PM   #83
Maybe we should close all threads with the objective vs subjective discussions. They have been going on for half a century. (Ps. I refuse to call it science based vs faith based). Because actually a lot of the so called "science" is faith based and visa versa.
Old 7th November 2009, 01:17 PM   #84
jlsem is offline jlsem  United States
jlsem's Avatar
I miss Charles Rodrigues more than I miss anyone who has deserted this forum.
John
Old 7th November 2009, 01:20 PM   #85
just another
wintermute's Avatar
I like the use of subjective vs objective Yes I guess that the so called scientists/engineers have faith that the fact that they know of no measurements that can demonstrate a difference, means that there is no audible difference
Tony.
Any intelligence I may appear to have is purely artificial
Some of my photos
Old 7th November 2009, 01:22 PM   #86
MJL21193's Avatar
Then clearly 90% of the "DIY" population wouldn't have anything to comment on. Days and sometimes weeks pass in valid project threads without a comment, positive or negative while these threads grow and grow.
It's somewhat ridiculous really.
Old 7th November 2009, 01:36 PM   #87
Banned
Discussion is good. It does seem to not find a common ground though. If these threads that you mentioned are so worthwhile, then why would people that were interested in them not comment on them? Sounds to me like people do not find them worthwhile or simply have no interest in them for some reason. How is that ridiculous?
Old 7th November 2009, 01:38 PM   #88
MJL21193's Avatar
Considering the venue, what have you built lately?
Old 7th November 2009, 01:41 PM   #89
45 is offline 45  Italy
45's Avatar
Originally Posted by SSassen View Post
Right, that's exactly my point, there's no reason for me to enter into this discussion if you seem to think that the laws of physics and mathematics that govern the operation of the equipment you use for audio recording and playback are based on 'pretty crude models'.
The only factor that we cannot quantify exactly is what happens between the ears, the belief system, psycho-acoustics, reputation of a product, word of mouth, etc. etc. That's why a proper DBT shows no differences between all those overpriced cables and a piece of standard copper installation wire. When you take all the nonsense that is belief and reputation of a certain product out of the equation and judge it on its 'sonic signature' (for lack of a better word) then suddenly it all sounds the same. Given the fact the listener is the only variable in a proper DBT what does that tell you? (of course the believers will argue a DBT is flawed, so we're going to go in circles).
Sander.
Physics cannot describe the human mind when it comes to sensation for a simple fundamental reason: the human mind is not time-invariant.
The human brain always makes a selection - according to unknown criteria - of the information you give it. It is never exactly the same from time to time and form place to place.
Time invariance is the basic hypothesis to apply the Fourier analysis.
The Fourier transform relates in a unique way time and frequency domains and that's what you get from measurements.
Unfortunately all this stuff has little utility (can just be useful to find the "right" direction to follow at the beginning) when you include the listener in the chain.
Medicine is science however it is empirical. The science of musical sounds is the same. Science has just one requirement: the scientific method (that is based uniquely on the observation of phenomena). It doesn't need formulas at any cost!
In the end music has been created empirically: try, listen, adjust, try again, listen again etc....
Old 7th November 2009, 01:49 PM   #90
Banned
I am building a set of tube mono block amplifiers, with separate power supply chassis for each channel. Tube regulated bias supplies and power on all stages, except the output at the moment. I hope to start building the cabinets for a pair of Grand Ekta speakers designed by Troels shortly in my wood shop also. Is that OK with you
Closed Thread
diyaudio moderator vs diyaudio member Leolabs Everything Else 6 18th June 2006 09:19 AM
What happened to... mikeks The Lounge 4 21st May 2005 01:08 PM
What happened to my cdp?? help!! ronardi Parts 11 25th July 2004 09:33 PM
Page generated in 0.10807 seconds (82.12% PHP - 17.88% MySQL) with 11 queries
