Old 6th November 2009, 04:09 PM   #1
sandyhooker's Avatar
Default Question on Midrange natural rolloff>>
I have two Audax HP130Z2 midrange units which have been discussed in this Forum and tested apparently by Zaph Audio . They have a tested Fs of 156hz.
I also have a recently acquired Rotel sound processing preamp which has a sub woofer out setup which rolls off at 150hz. My intention is to use three amps ,two for left-right mid and upper freq and one for the sub. I should also disclose that the sub out on the preamp can be set at 50hz,150hz or FLAT. The flat setting I assume is for FULL RANGE.
I plan to end up with three boxes ,two small and one much larger tuned to 35hz.
My question is will the natural rolloff of the Audax unit be low enough to make this work???
Old 6th November 2009, 05:25 PM   #2
Inductor's Avatar
I would say go with it (even if difficult, I don't know). You can always use the 150Hz filter or Flat for your tests also depending on woofer. You will have an inductor I guess for the mids and passive xover for tweeters. The Fs (mids) is high, but since you have a good margin to play, (and some hardware) to make experiences and you already have them, I would test it. After all this is going to depend a lot on the (new?) woofer/sub driver merging (mid) frequencies.
Xing refs: T/S for HP130Z2 ??
T/S for HP130Z2 ??
Natural dielectrics (in caps and wire) like silk, paper and cotton sound more natural Bas Horneman Parts 135 29th September 2009 11:41 AM
Midrange driver question. a007udio Multi-Way 11 21st January 2008 09:56 AM
Natural rolloff vs. LT same Q Cro maniac Subwoofers 1 31st August 2005 02:06 AM
JBL Midrange Question Regis Multi-Way 3 29th January 2004 10:04 PM
question on rolloff below 100Hz wintermute Chip Amps 4 16th December 2003 03:23 AM
Page generated in 0.06267 seconds (69.78% PHP - 30.22% MySQL) with 10 queries
