Old 5th November 2009, 09:08 PM   #1
mattmcl is offline mattmcl  United States
Default Test crossovers?
Is there a way to test crossovers with a multimeter? I would expect I could hook up the xovers to my amp, play a certain frequency, and be able to tell if the xover is sending that frequency through to a specific driver or blocking it. Thanks.
Old 5th November 2009, 09:35 PM   #2
I am also new to building crossovers. The crossover does not stop frequencies outside of their range, they simply attenuate them, I think.
Old 5th November 2009, 10:00 PM   #3
Inductor's Avatar
The speaker drivers are an integral part of the xover. So that's not possible unless you consider the complete electrical circuit in simulations or in real measurements.
Old 5th November 2009, 10:59 PM   #4
whats attenuate mean please
Old 6th November 2009, 12:39 AM   #5
just another
wintermute's Avatar
basically means to reduce in level. ie make sound softer.. the higher the attenuation the less loud the sound will be. The filter order will determine the slope of the attenuation, with first order attenuating at a rate of 6db / octave.
Say your crossover freqency is 500 Hz... this means that at 1000Hz the signal level will be 6db lower than at 500Hz
higher order crossovers attenuate more rapidly, basically second order at the rate of 12db/octave 3rd order at the rate of 18db/octave etc.
depending on who you listen to, either -6db or -10db corresponds to a halving of the volume level.
Hope that clears things up a bit
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 6th November 2009, 12:45 AM   #6
just another
wintermute's Avatar
If you have a cheap full range speaker you can easily connect it to each point in the crossover, and play your specified freq to see how much that is attenuated for the different points... it will only be points a *long* way past the crossover freq that you should get no sound at all.
You could use a multimeter with a freq function I guess. The AC of most cheap multimeters doesn't work well with high frequencies.
Tony.
Some of my photos
Old 6th November 2009, 01:22 AM   #7
gedlee is offline gedlee  United States
These days with uber-cheap software and soundcards there is simply no reason to use a "multimeter" for this kind of thing.
Old 6th November 2009, 06:38 AM   #8
chris661's Avatar
winISD has it's own frequency generator.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 6th November 2009, 11:31 AM   #9
You can use your VOM for electrical tests but you'll need a tone generator that you hook up to your amp or, get a CD that plays discreet test tones. Set your VOM on AC voltage and hook up the leads to whichever driver xover output termimals you want to test and record the voltages as the tones change. You should get a steady peak voltage in the pass band range and a drop off in voltage outside of the pass band range.
Another way to do this is hook up the crossover to a speaker as others have suggested and acquire a sound level meter. These are relatively inexpensive. Set the meter in front of the speaker and go thru the test tones and record the dB levels. You can plot the results M'Soft excel or other type of spreadsheet software.
crossovers tonysherwin Multi-Way 3 18th May 2008 12:30 AM
Can You Test Crossovers Directly BillM Multi-Way 8 8th January 2008 06:02 PM
Is there any test cd to test jitter using a scope ? gaetan8888 Digital Source 4 10th August 2007 09:24 AM
MMG Crossovers - Anyone done this yet? john65b Planars & Exotics 0 31st December 2006 08:59 PM
2.5-way crossovers sriegel Multi-Way 2 30th April 2002 05:47 AM
Page generated in 0.10091 seconds (80.45% PHP - 19.55% MySQL) with 10 queries
