passive line level BSC?x-overs? any pointers?
Old 4th November 2009, 02:54 AM   #1
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Default passive line level BSC?x-overs? any pointers?
my current loudspeaker project, has a passive power level x-over and no BSC as i intened to use the speakers within a foot or two of the wall(small apartment 5x4m square virtually makes a necessity).
basically, Do i need BSC? i dont think id need an awful lot, maybe 1 or 2dBs, but the narrow baffle i have in mind may make matters worse.ive calculated the loss to occur up to about 650Hz, as my baffle is 7 to 8" wide. Anyone have any links that could help?
also anyone have any links or advice that could help with replacing my passive speaker side xover with a line level one? particularly, as its 2nd oreder electrical, 3rd acoustic lowpass and 3rd elec, 4th acoustic high pass;with additional resistor to control the slope.
i understand how this works in the speaker side network, but am not 100% sure how to implement it in a line level passive network. though i suspect it is more similar than i imagine.
Old 4th November 2009, 04:10 AM   #2
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Passive Line Level Baffle Diffraction Step Compensation
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th November 2009, 06:43 AM   #3
CLS is offline CLS  Taiwan
I'd like to add that the line level BSC also works very well with my Fostex active mini-monitor (PM0.4) when used with TV in the living room.
That mini-monitor is designed as a near-field monitor on the deck of mixer console. When used in my living room, with the larger space and further listening distance (than the original design target), the response is far too bright / bass shy. Then I made this simple RC circuit in front of the line level input of that active little speaker with a tiny board and integrated with the signal cable. It turned out very well and now sounds much more richer and fuller in tonal balance.
Old 4th November 2009, 07:33 PM   #4
PeteMcK is online now PeteMcK
Baffle Step Compensation
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
passive line level BSC?x-overs? any pointers?Hide this!Advertise here!
Passive line level x-over - CAN IT BE DONE? hasselbaink Multi-Way 35 13th September 2016 02:03 AM
Line level passive BSC rhapsodee Multi-Way 1 27th July 2009 03:09 AM
Line-level passive crossovers vdi_nenna Multi-Way 3 16th June 2005 12:39 AM
Passive line level crossover rulezzz Multi-Way 3 7th January 2004 09:45 AM
passive line level XO peterr Everything Else 1 5th March 2003 09:07 PM
