Tweetertalk.... Go!
Tweetertalk.... Go!
Old 3rd November 2009, 12:11 AM   #1
raypalmer is offline raypalmer  Canada
raypalmer's Avatar
Default Tweetertalk.... Go!
So I'm working on these threeways. I've purchased a set of piezo horns out of curiosity but don't really intend to use them as a final solution (unless they wildly exceed expectations).
What are the forum's thoughts on piezo tweeters?
Also;
Anyone know of a nice cheap 8 ohm tweeter at or above 90dB efficient?? I've never had much luck with cheap tweeters and can't afford expensive ones. Could use a hand.
Wherever you go there you are.
Old 3rd November 2009, 12:26 AM   #2
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Tweetertalk.... Go!
I hope to make the TB W2-800SL 2" work
So far, from quick listen, I think it may have potential, if handled with care
It might prove to be almost ideal fore MTM design, with the possible very low xo point
A very low xo point might also make it much easier on the BSC matter
But it will take some time before I know it better
Old 3rd November 2009, 01:43 PM   #3
Inductor is offline Inductor  Portugal
Inductor's Avatar
The LAST good (piezo) tweeter was the one Wayne P. used in his PI Speakers before changing it to the Vifas and having it available as an upgrade kit for some time. Now the trend is the ribbons. There are many very good (cheap) dome tweeters, as you go read from previous posts.
(As an (1) example of a tweeter, depending of your application, there is this "K1 Hi-end Tweeter" for a very reasonable price)
Product information:K1 Hi-end Tweeter
Hi-Vi K1 1" Fabric Dome Tweeter, 116 mm Flange from Madisound
Tweetertalk.... Go!Hide this!Advertise here!
