I have a pair of Rokit 5's I bought used and one of them may be exhibiting symptoms of the 5" mid being blown, and I would like to be able to inspect and replace it. However, I am stuck at how to actually take these apart. There are many screws on the back holding the amp on, but when I remove all of the perimeter ones nothing will budge, and the remaining screws in the center of the plate amp have little resistance when unscrewing, indicating that they are not holding the amp in place. Here is a picture to illustrate this: ![]() Is it possible there is some kind of sticky gasket or glue holding the plate amp in place? Do I have to pry the amp out? Anyone have any experience with these or how to actually get them apart? Thanks in advance.
.: Got a question? Modding is the answer :. |
#2 |
I suppose it's a lost cause then.
#3 |
frugal-phile(tm)
I would guess there is a gasket. And it wouldn't be unexpected for it to be a tell-tale that they have been dissassembled.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
I'm not worried about resale, or anyone knowing I took them apart, I just want to be able to open them without damage. I won't be sending them to KRK ever, and I'll probably keep them around until they die, so I want them to have a useful life.
It would suck if KRK put that gasket in just to deter people from fixing it themselves. I've seen raw drivers for them being sold on ebay quite regularly, so there must be other people somewhere swapping drivers out... so at least its not impossible.
#5 |
frugal-phile(tm)
The back has to come off... can you pop the drivers (woofer) out to look inside the box?
dave
#6 |
frugal-phile(tm)
The 4 allen bolts on the front are worth removing to see if the front comes off...
dave
#7 |
Only undo the screws around the outside , the inner ones hold the amp internals to the backplate. Probably has a gasket *of sorts* and will need a bit of "encouragement" to get it out...........
#8 |
Well after a few hours I finally got it, I had to end up shoving the amp plate out via the port on the front using a dowel, the gap between the amp and the enclosure was so tight it was impossible to get anything between there to pry it out. Mine is the v1, so it doesn't have the allen bolts on the front, but the trim ring around the speaker was only held in with friction and some asphalt-based adhesive so after about 20 mins with a butter knife I was able to remove it and get at the screws and get the woofer out.
I still can't discern if its fully blown, since it only makes a light buzzing noise during certain low notes at considerable volume levels, but further testing will eventually yield the answer to that one. This was my 2nd attempt and it took me about 45 mins overall just to get it taken apart, it really is impossible to get the amp off without nudging it from the front first, which is what I failed to try before. Thanks for all the tips guys, and hopefully if anyone else ever has this problem they can gain a little help from this thread.
.: Got a question? Modding is the answer :. Last edited by MbayAQ; 4th November 2009 at 05:58 AM. |
#9 |
frugal-phile(tm)
Some pictures of the inside please?
Can you run an impedance curve on the "bad" woofer? dave
#10 |
I can get some pics up tomorrow no problem, and would running an impedance curve require a woofer tester?
| New guide from TI | FastEddy | Parts | 0 | 19th August 2007 08:36 PM |
| First go at it without a guide or kit..............HELP!!!!! | Gavinator68 | Multi-Way | 1 | 9th November 2005 07:33 AM |
| speaker guide | jeffers696 | Full Range | 6 | 20th May 2005 05:16 PM |
| what is a wave guide? | Joules | Multi-Way | 7 | 12th May 2005 02:25 PM |
| Page generated in 0.09597 seconds (80.56% PHP - 19.44% MySQL) with 11 queries |
