Old 27th October 2009, 08:57 AM   #1
Banned
Default What happens to port dia/length when an enclosure is doubled?
The (single woofer) cabinet spec for the woofer I'm implementing is:
.60 cubic feet w/ 2" dia x 6.25" length port.
I want to use two of the woofers, and I have a 1.2 cubic foot box ready to go. So, does the port spec double as well? ie 4" D x 12.5" L?
Old 27th October 2009, 09:12 AM   #2
chris661's Avatar
No, it stays as it is.
Changing the port diameter and length changes the tuning, but with twice the box size and twice the woofers, the tuning will stay the same. Try it on something like winISD.
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 27th October 2009, 09:21 AM   #3
Banned
how simple! thanks!
Old 27th October 2009, 11:32 AM   #4
Chris
I disagree. Doubling the number of woofers has no direct impact on the vent calculation. It is strictly a function of the port size, tuning freq. and box volume as dictated by the helmholtz formula.
Port Length = 14630000*R^2/fb^2*Vb - 1.463*R
where R is the port radius in inches
where fb is the tuning freq.
where Vb is the box volume cu. inches
Based on your info., your port freq. is about 43 hz.
Doubling the vol. will reduce the port length to 2.4 inches with a 2 inch dia port.
If you increase the port dia. to 3 inches, then the port length can stay about the same (actually 6.4"). This is advisable to minimize chuffing (high air volicity noises in the port tube)
port length jwhit67 Multi-Way 1 6th March 2008 12:29 PM
Help with port length please Bobhof Multi-Way 3 2nd May 2006 06:32 PM
port length busterno1 Multi-Way 5 27th October 2003 08:05 PM
port length dave k Multi-Way 13 13th July 2003 02:32 PM
Page generated in 0.07461 seconds (74.21% PHP - 25.79% MySQL) with 10 queries
