I have just finished measuring some t/s parameters using the method described in Weems' book.
I would now like to calculate BL. I have used an equation i found here in another thread but i get an answer which to be at least seems a little off, i get about 2 when the published spec states 5.6. im not sure im using the wrong units or something. my measured specs are: Qms 4.750 Qes 0.450 Qts 0.411 Sd 0.0078 m² Fs 47 Re 5.6 Vas 10.823 litres Any help or advice would be appreciated. THanks |
#2 | |
can a mod remove this lol i was using litres for Vas and not m³.......silly mistake ....doh! |
#3 |
in my web (sorry in greece)
http://www.speakerlab.gr/papers/parameters.pdf 1. find Cms=Vas/(1.18*345^2*Sd^2*10^8)= 1,25 mmN 2. find Mms=10^6/(Cms*4*3,14^2*Fs^2)= 9,15 gr 3. find BL=[(Re^2*Mms)/(Qes^2*Cms)]^0,25 = 6,30 Tm |
#4 |
1. find Cms=Vas/(1.18*345^2*Sd^2*10^-8)= 1,26 mmN
Sd in cm^2 yours=78 cm^2 2. find Mms=10^6/(Cms*4*3,14^2*Fs^2)= 9,06 gr 3. find BL=[(Re^2*Mms)/(Qes^2*Cms)]^0,25 = 5,77 Tm stavros |
#5 |
As a quick and painless solution run Unibox. It provides BL as a product of the driver parameter entry. Also, one of Martin King's Mathcad worksheets includes a BL calculation.
Good luck, --Steve |
#6 |
Did it Himself
Were you the guy getting funny readings using Rod Elliot's method? Did you figure out what the problem was?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#7 |
What Gustava said; Winisd does the calculation too.
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#8 |
#9 |
mondogenerator:
Using Martin's T_S_Consistency_Check_Vad worksheet, it generates the following results with your data: Cms = 1.248 mmN Mms = 9.192 gm and BL = 5.812 newton/amp (or Tm) I worked through stavros' results by hand and think the difference is simply his rounding off numbers such as Pi. The published spec is quite close to what you've measured. Martin's worksheets are great and well worth the cost! |
#10 | |
I used the equation from an old post on here that someone else wanted for a BL calc, and substitued the numbers into excel..i get 5.787 and i round to about 3dp. its close enough to the 5.6 specified for me to be happy, in fact higher so im a little happier! thanks anyway rfor you help but i wont be needing MJK's sheets any time soon, as useful as im sure they are. I prefer a pen and paper or just excel lOL |
| looking for diy guy to assist in some prototype equipment | xov | Everything Else | 4 | 19th October 2007 02:37 PM |
| Assist software | EricD | Parts | 0 | 17th September 2007 10:16 PM |
| Golf Balls cut in half to assist turntable suspension? | Audio Addict | Analogue Source | 16 | 4th May 2007 12:30 AM |
| Please assist with a Vifa design | amo | Multi-Way | 25 | 14th October 2004 11:22 AM |
| Page generated in 0.11493 seconds (84.94% PHP - 15.06% MySQL) with 11 queries |
