Old 25th October 2009, 07:55 PM   #1
Default Need Simple Help
Hey guys. I'm building an 2-band crossover and there is one very simple thing I don't understand: what amplifiers do I use after the signal has been passed through the crossover?
OK, so if this is my system setup:
How do I determine what amplifier I need right before the sub, and before the tweeter?
Old 25th October 2009, 11:51 PM   #2
Francec is offline Francec  Australia
Banned
Default Two way active
Hi Vector,
What is the crossover frequency, which drivers are you using and what do you want of the speaker?
Frank
Old 26th October 2009, 01:29 AM   #3
Hey Francec. Thanks for the quick reply. I know about electronics, but I am brand new to the audio circuits. Here is a MultiSim Schematic I made of the crossover.
http://i586.photobucket.com/albums/s...rSchematic.jpg
And here is a dB Gain frequency response plot of each output.
http://i586.photobucket.com/albums/s...cyResponse.jpg
From that info could you help me figure out what the crossover frequency is, which drivers I want and what I do want of the speaker?
These are new concepts to me. Much help needed.
Old 26th October 2009, 03:08 AM   #4
BiAmp (Bi-Amplification - Not Quite Magic, But Close) - Part 1
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 26th October 2009, 07:14 AM   #5
Moondog55's Avatar
Tweeters only need a few watts so use the smallest amp you have for the HF I use 250watts for my midrange and 250 for the bass, when I Tri-amp I have a little 70watt amp here and I think that is probably just a little too much
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 26th October 2009, 08:09 PM   #6
Do typical computer speakers have a little amp in it already?
If so, then could I just use one of those as to pass the high's to?
And a 250W amp would do fine to power the Sub to pass the low's to?
Once again, I know little about audio. So any advice helps me out.
Old 26th October 2009, 08:56 PM   #7
Banned
You can do this, but powered speakers rarely have as much as 10W rms and often sound bad when driven hard. 250W is probably way too much to go with computer speakers, a typical COTS system has 8W L&R with 22W sub.
w
Old 26th October 2009, 10:58 PM   #8
"How do I determine what amplifier I need"
- base this on a: how loud you want to play; b: how big your room is; c: your budget.
in theory, for headroom, you need the same size amp for HF as LF, in practise you can get away with a somewhat smaller amp for HF.
Of course, you need to decide this and the crossover freq of the crossover unit AFTER you've decided on your speakers.
It's not clear whether you're going for a sub+satelite or 2-way woofer + tweeter system.
typical computer speakers and their amps are a waste of time.
For speakers of reasonable efficiency, 40w is more than adequate
Old 26th October 2009, 11:20 PM   #9
I'm not really that interested in quality. This is for a school project. I just need to demonstrate that I am splitting the audio spectrum into two separate frequency bands.
So what speakers and amps would you guys use to achieve this goal?
Old 27th October 2009, 02:43 AM   #10
Pano is offline Pano  United States
Pano's Avatar
It doesn't matter what amps you use, as long as they have "enough" power. And it matters that they have a volume control.
The main thing you want to worry about is that you get the gain right. Everything after that is just frosting on the cake.
Simple Simple SE questions nodiak Tubelab 57 2nd February 2010 11:02 PM
Simple, SIMPLE Digital volume control -_nando-_ Digital Source 5 21st December 2006 01:20 PM
A simple question from a simple man. inteificio Solid State 5 17th October 2005 03:00 PM
Simple (or not so simple) decision wxn Chip Amps 4 5th November 2004 09:55 AM
Simple answer required for a simple question... rabbitz Multi-Way 4 31st August 2003 10:05 AM
Page generated in 0.09685 seconds (87.90% PHP - 12.10% MySQL) with 10 queries
