Soakin' up the Sound!
I picked these up today for $5. They're very solid and heavy. Other than that...???
Any ideas? Thanks, Mike
#2 |
frugal-phile(tm)
No idea... nice looking tweeter thou.
Numbers don't coorespond to anything EIA, i'd guess Japanese, the metal work looks like some of the more exotic foster or corals i have seen. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 | |
They're about 3 - 4 inches across. Will a WT-3 give me any usable info about them? I picked up a pair of Dynaudio 17W-75 speakers along with them. Any way to tell if the two would be a good match? Thanks, Mike
#4 |
frugal-phile(tm)
WT-3 will give you an impedance curve which will give you info about how low they can cross, and whether the cone has any serious resonances.
I suspect that you might have trouble integrating them with the Dyn, but the tweeters are probably designed to be run with a single cap in series, so it would be pretty simple to try them together and (if it rolls off smoothly) let the Dyn run out of steam on the top naturally. dave
| DIY Mystery Speakers | reganzi | Multi-Way | 5 | 25th June 2009 10:53 AM |
| Mystery RF amp | spooney | Car Audio | 11 | 25th April 2008 06:14 PM |
| little 6.5 mystery ... | oface | Full Range | 6 | 4th November 2007 11:20 PM |
| Mystery SE OPT | alexmoose | Tubes / Valves | 4 | 11th July 2006 01:29 AM |
| mystery... | mista2 | Multi-Way | 1 | 14th January 2005 04:20 AM |
| Page generated in 0.07384 seconds (70.64% PHP - 29.36% MySQL) with 11 queries |
