I know that to measure normal speakers you want them as far away from barriers as possible, but what if you are designing "on wall" speakers? Shouldn't they be measured on wall?
Just curious. |
#2 |
2Pi loading can be against any boundary.
Lying face up on the floor/in a field/on any flat hard surface, would be easier than testing in a room.
regards Andrew T. |
#3 |
There are two main standards that I know, to measure in a standard box or in a standard baffle, that's all. It doesn't say it's a lot different for your wall. Use The Edge (Tolvan/The Edge) software to simulate for baffle size. Look at different methods to measure loudspeakers, in open fields vs. anechoic chambers. You have a lot of homework to do.
#4 |
Yea, the 2Pi method sounds like a winner.
| Dumb question, but... | johnm | Tubes / Valves | 3 | 13th June 2008 10:14 PM |
| Dumb question. | G | Tubes / Valves | 2 | 16th January 2008 08:16 PM |
| maybe this is too dumb a question... | dannyspencer | Solid State | 6 | 18th April 2004 04:57 PM |
| Thi is probably a dumb question.... | Konnan101 | Multi-Way | 4 | 11th January 2004 01:40 PM |
| Dumb Zen V4 Question | Panelhead | Pass Labs | 4 | 26th April 2003 04:15 PM |
| Page generated in 0.07782 seconds (74.38% PHP - 25.62% MySQL) with 10 queries |
