Old 22nd October 2009, 05:01 PM   #1
thadman is offline thadman  United States
Default Calculating Acoustic Radiation from apertures driven by Ribbon Loudspeakers
Originally Posted by A Method of Loudspeaker Directivity Prediction Based on Huygens-Fresnel Principle
According to the Huygens-Fresnel principle, the wave emanated by some source can be considered a group of point sources, located on the primary wavefront surface and radiating secondary spherical wavelets
For a calculation of a complex pressure outside of the radiating device, it is necessary to know complex pressure in the exit aperture.
http://www.aes.org/tmpFiles/elib/20091022/12398.pdf
For compression and dynamic cone drivers, they might be approximated as pistons below their fundamental mode. We might assume uniform velocity over the surface of the piston, however we can not make such assumptions with regards to ribbon loudspeakers. Their surface does not move with uniform velocity (maximum at center, 0 at boundaries).
How can we calculate the complex pressure in the exit aperture for a ribbon loudspeaker located in a rectangular duct?
I would be very appreciative if you are able to contribute any knowledge or information (journal articles, texts, etc) regarding this phenomenon.
Thanks,
Thadman
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them."
Old 22nd October 2009, 06:08 PM   #2
this link might help.
Scroll 1/2 way down for the ribbon radiation patterns.
Ribbon Wavefront Patterns
Current Driven Loudspeakers and Tranconductance Amplifiers Tube_Dude Multi-Way 263 24th November 2010 07:21 PM
Sources of distortion in ribbon loudspeakers thadman Multi-Way 1 1st July 2009 06:38 PM
Calculating loudspeakers enclosures Arnold_R Multi-Way 0 20th October 2004 06:09 PM
Page generated in 0.06171 seconds (69.34% PHP - 30.66% MySQL) with 10 queries
