LR xover question
LR xover question
Old 20th April 2004, 02:33 PM   #11
Ken L is offline Ken L  United States
Default Still thinking about this _big grin_
Question Please Sreten?
Originally posted by sreten
Your procedure is effectively phase aligning the
drivers at crossover not time aligning them.
So phase worries are not an issue .
sreten.
I understand what you are saying - my question is -
Assuming that there are several physical points at which the drivers are in phase -
If the drivers actually become time aligned -
Wouldn't the point of Time alignment also be the point of _deepest_ null?
Just trying to make sure of this -
Thanks for your input.
Ken L
No longer powered by Linux - not enough apps and cross platform integration - but maybe one day
Old 20th April 2004, 04:51 PM   #12
R.I.P.
Default Re: Still thinking about this _big grin_
Ken L
It depends how you define time aligned.
However phase alignment of the crossover implies you try
the tweeter out of phase and use the the point will a null
that has the lowest apparent acoustic centre offset, for
minimum phase change through the c/o region.
With a first order crossover it depends how well the drivers
own phase shifts have been accounted for as to whether
the drivers will actually be time aligned.
With non symmetrical crossovers, and acoustically nearly all
are even if they are electrically symmetrical, the point of best
phase alignment is not the point of equal acoustic delay
from each driver in their passband away from the c/o region.
A good crossover designer exploits this to allow offset drivers
on a flat baffle to have near perfect phase alignment.
sreten.
Old 20th April 2004, 09:12 PM   #13
Default Re: Re: Still thinking about this _big grin_
sreten.
Thanks for your response, Sreten.
I've still got a lot to learn about this stuff _grin_
Best regards
Ken L
LR xover questionHide this!Advertise here!
Passive xover question ttako Multi-Way 1 23rd February 2009 08:46 PM
Xover Coil R/Ohm Question trummis Multi-Way 6 18th April 2008 02:35 PM
xover question; will this work? matjans Multi-Way 7 1st June 2004 12:29 PM
Rare JBL Xover question. Netlist Multi-Way 4 7th February 2003 08:56 PM
Xover question namotvi Multi-Way 1 23rd November 2002 04:40 PM
