The first is Zaph's ZD-5:
Zaph|Audio - ZD5 - Scan Speak 15W8530K00 and Vifa XT25 I don't know why Zaph thinks a 2nd order x-over is better than a 1st order? Could Jim Thiel be wrong? Quoted here: 'But when everything comes together for a LR2 system, it's the sweet spot in speaker design. Why is it the sweet spot? Because the next step is no crossover at all in a full range driver, which is a step backwards, introducing a whole different set of problems that detract from good sound. " So going with Zaph's argument, the next step is no x-over. Audio technology has such a driver: Flexunits 5 H 52 15 06 SD I spoke with them and they told me I could run the driver full-range and put a hi-pass x-over for the tweeter. So what do you think? Comments would be appreciated. |
#2 |
The next step is NOT a fullrange driver with no crossover - I think you're misinterpreting what Zaph is saying - he means that's going in the wrong direction.
You CAN run drivers without filtering, but you won't get the best performance. There are few if any drivers, fullrange or otherwise, than will not benefit from filtering. As for the FlexUnits, I'd recommend searching the forum for projects/testing/feedback and see what others have to say about them. As for the ZD5, it's probably up there with the best of the best, but personal taste is always a factor in design selection and satisfaction.
Soft Dome |
#3 |
Very nice chuck,
what's the next step? There's a lot of work in front of you. (and I'm not talking about the money) The driver looks very good. |
#4 |
This one bears watching, as it seems that it may be even better than the Exodus Audio "Kepler". While the exact price for components isn't possible, as the exact configuration of the crossover hasn't been finalized, this would be a very high-value design.
Here's some plots and current discussion: Anarchy DXT Fun Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#5 |
Inductor, Thanks for the interest. Per Audio Technology, the 4" Flex unit is $308 USD each. It can be run full range with no filter however power handling is a bit lower. Just need a tweeter with a 3rd order x-over.
I read a thread here about Morel and Dynaudio sounding slow or lacking life or something. Lots of people said they did not like them. This hit a chord with me as a big heavy cone will need more power and I can understand the slow/ heavy sound concept. So I'm more leaning towards the Seas coated paper cones like Snell's K7/J7. They need 1/2 the power (50W vs 100W) which is more what I like as I don't play speakers loud and want the driver to come to life at lower volume levels. I'm sure the Morel and Audio Technology are nice, very nice, but not sure if they fit my listening style. I've pretty much given up on full range single driver speakers as anything over 3" has terrible breakup modes which hurt my ears. And 3" lacks bass and clarity. I may have to bite the bullet and go with a x-over 2-way to get what I need. As Zaph says, full range are for people who are afraid of x-overs. That's me, as I realize I don't know what I'm doing designing an x-over. Problem is, Zaph gives no support and I am hesitant to put so much time and money into something which I may not even like and has little resale value. So Inductor, what do you have for speakers? |
#6 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
#8 |
frugal-phile(tm)
He is entitled to his opinion.
dave
#9 |
So what do you recommend Planet10?
#10 | |
There are drivers that from time to time is claimed to not needing to be low-passed. Vifa P13WH comes to mind.
The real world is a bit different though, as xo is not only dealing with frequency but polar response, distortion etc. Zaph's design mantra stated: Quote:
http://gainphile.blogspot.com Last edited by gainphile; 27th November 2009 at 05:18 AM. |
| ESS AMT 1 A (B, C, D, E) Monitor into ESS AMT 3 Rock Monitor | cdfr | Planars & Exotics | 4 | 15th October 2010 03:38 AM |
| Ultimate BLH FR? | Pano | Full Range | 13 | 2nd April 2009 03:49 PM |
| The A4 monitor, best mini monitor? | KURT | Multi-Way | 5 | 26th April 2005 01:34 PM |
| Ultimate HT sub? | bhg41088 | Multi-Way | 15 | 11th April 2004 08:04 AM |
| Page generated in 0.11780 seconds (80.52% PHP - 19.48% MySQL) with 11 queries |
