Old 19th October 2009, 03:23 PM   #1
Default Baltic Birch/Particle board sandwich.
My diy speaker project is slowly coming along as there are so many choices and compromises that have to be made. Sooo, CLD is out of the question as I don't have the skills nor patience to make it work.
That's why I'm thinking of sandwiching particle board between 2 sheets of BB, something in the order of 12 mm BB (exterior), 9 mm particle board, 6 mm BB (interior). On the front baffle I plan to add a 6 mm thickness of BB (glued to the 12 mm BB exterior) which avoids having to rebate the BB to accommodate the drivers. I may also end up veneering the cabinets but we'll see...
For enclosure stuffing, it looks like Ultra Touch (cotton/denim) would be a nice choice but I'm not sure about thickness or density. The design is a 2 way aperiodic (closed box though) design based on the Dynaco A 25 (World Designs WD 25T, building plans available on their site).
Drivers: SEAS A 26RE4 (10" mid/bass)
SEAS T29CF001-06 (excel tweeter)
The system will be "active" and I'm considering a Marchand analog XO. SS amp on the mid/bass and tube amp on the highs. ARC D130 and VT 50.
Since I'm likely to use BB instead of MDF, I'm wondering if more bracing is essential as the only negative I've read about BB is its flexibility. So the front baffle should come out to 33 mm (almost 1.5") and the rest of the panels to about 27 mm (few hairs more than 1")...
I'd appreciate any advice you guys have to share as to the glue, stuffing, bracing, exterior finish... and no screws are used for this project (except to secure the drivers).
Thanks for your help.
Old 19th October 2009, 05:15 PM   #2
MJL21193's Avatar
How big is the box? What are the dimensions (W x D x H)?
Your effort is almost certainly better spent effectively bracing the box, rather than making the panels excessively thick.
Old 19th October 2009, 05:27 PM   #3
Internal dimensions are approximately 935 mm H x 250 mm W x 210 mm D. The plan already has 3 horizontal braces and 1 vertical brace.
Old 19th October 2009, 05:42 PM   #4
badman is offline badman  United States
Custom Title
badman's Avatar
I'd go about 2" thick on 3 of the walls, excluding the bottom, baffle, and one side. Keep the densitity about what you find in the ultratouch as sold.
With the wall thickness you're doing it is improved over a normal 18mm wall. I like to overbrace, but it isn't strictly necessary, particularly with your layered wall construction. Stock bracing scheme may be sufficient. Always focus effort on the biggest area without a brace, and try to couple opposite walls to each other.
Use good jointing technique with your laminated material. Rabbeted joints are a good mix of strength and ease. Be sure to coat all cut edges with woodglue, and coat the inside of the cabinet with something. Particle board will be problematic with moisture, so you must be very sure to seal it well.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 19th October 2009, 05:47 PM   #5
frugal-phile(tm)
planet10's Avatar
A bale of 3.5" is probably your best bet.
Do you know that Scott & i did a TL for this WD kit?
Classic TL Revisted
The reason to use BB is that it is stiffer & better damped than MDF. It is always hard to overdo the bracing.
Discussion on what materials to build speakers out of
(what is missing from that thread is the post where John has an epiphany and relizes what i'm describing)
New search is truly better Discussion arising from Geddes loudspeaker
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th October 2009, 05:50 PM   #6
MJL21193's Avatar
I would build the entire box out of 3/4" BB plywood (or MDF if you like) and have 3 full panel holey braces that run from top to bottom - 2 from front to back, cutting the panels into three spans. The other (actually 3 separate pieces) from side to side:
The braces can be 1/2" thick.
Old 19th October 2009, 06:03 PM   #7
MJL21193's Avatar
dave
Good snag Dave. I forgot about that "discussion"
Old 19th October 2009, 06:25 PM   #8
frugal-phile(tm)
planet10's Avatar
Originally Posted by MJL21193 View Post
What John shows is very good.
Keep this detail in mind:
A brace should divide a panel into subpanels such that the aspect ratio of the subpanels are higher than the original panel and such that the aspect ratios of the subpanels are not equal.
dave
Old 20th October 2009, 04:14 AM   #9
Thanks so much for the input guys, I still have much to learn. I've been reading up on speakers and have read many threads here on the matter but still have a ways to go. John's plan seems to be quite similar to the original plans of this kit so it seems these guys knew what they were doing.
I've also been reading up on an old BBC research into loudspeakers that many of you are aware of but I include for those who have never had a chance to sift through it.
Here it is:
http://downloads.bbc.co.uk/rd/pubs/reports/1977-03.pdf
So, I'll read up on the links provided and keep badgering you with questions.
Thanks so much for the help!
Old 20th October 2009, 04:42 AM   #10
Classic TL Revisted
dave
Well Dave, I realize you know about Peter's (Comeau) mdf/particle board sandwich for the 2nd version of the WD 25. I just thought that sandwiching particle board between 2 sheets of BB may yield better results even though more costly.
I'm also looking up your Classic TL based on that design. Thanks for the links!
Super baltic birch Illusus Everything Else 59 17th January 2011 02:44 PM
Stain on Baltic birch flaevor Multi-Way 10 12th November 2006 12:15 AM
stain for baltic birch ply? slappomatt Full Range 13 7th March 2005 09:17 AM
Baltic Birch and MDF? downward_dog Subwoofers 6 12th January 2005 11:09 PM
Where can I buy Baltic Birch Plywood? Richard Moon Multi-Way 3 4th December 2003 12:51 AM
Page generated in 0.14812 seconds (83.31% PHP - 16.69% MySQL) with 11 queries
