For large scale events, ie music festivals (Bonnaroo, Lollapalooza, Melt, etc), loudspeaker arrays are often used.
What are the traditional requirements for such arrays? -How large of an area are they expected to cover? How large of a distance are they expected to produce appreciable SPL? -Over what angles are they expected to produce sound (ie directivity)? -How large of sound pressure levels are they expected to provide? -Are there other circumstances where use of such an array would be desirable? if you have any further information relating to requirements for large format concert arrays it would be much appreciated. Thanks, Thadman
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them." Last edited by thadman; 16th October 2009 at 11:22 PM. |
#2 |
They are modular , so easier to move and to stack .
They are black , so thousand of people standing in front of them would look at them only if asked . I would expect the same amount of paralleled devices in power amps. |
#3 |
Banned
Are you talking about hanging a logarithmic spaced, articulated spiral array in a horizontally asymmetric configuration employing frequency tapering and divergence shading, which will include isophasic high-frequency and mid-frequency apertures, hyper-cardioid low-frequency transducer sections, and that is controlled by finite-impulse response filtering digital signal processing, and one that works well with a psychoacoustic infector?
Live Sound - Pro Sound Web |
#4 |
Worth a read if you are interested.
The Birth of the Array Part One – Concert Sound Overview The Birth of the Array: Part Two Did I Hear Someone Say “Line Array?” The Birth of the Array: Part 4 The Birth of the Array: Part 5 The birth of the array part 6: the sixty-edged sword called reverb Birth of the array part seven: So what about the stacks and racks of the future? Birth of the Array Part 8: The French Connection (Correction) |
| emulating concert visuals with a LARGE format LED display, any technical advice? | thadman | Everything Else | 7 | 25th June 2009 11:57 AM |
| Economical large format bass-horn | broughd | Subwoofers | 11 | 8th January 2008 04:18 PM |
| Very large arrays | Prune | Multi-Way | 2 | 3rd January 2005 06:27 AM |
| Page generated in 0.09585 seconds (76.44% PHP - 23.56% MySQL) with 10 queries |
