Tone control ckt using TL072 - diyAudio
Old 13th October 2009, 03:38 PM   #1
Angry Tone control ckt using TL072
without using split power supply, how to bias the IC tl072, power supply available with me is 0-45VDC. This same power supply is used for power amplifier, therefore I want to use this same power supply for preamplifier also. Which would be the easiest method.
Old 13th October 2009, 04:38 PM   #2
Speakerholic
Cal Weldon's Avatar
You have posted this in loudspeakers. Where do you really want it?
planet10 needs your help:
Let's help Ruth and Dave
Old 13th October 2009, 04:52 PM   #3
sangram is offline sangram  India
Use a potential divider to create a half supply point, buffer with a small capacitor - and run the input resistor to that point instead of ground. Coupling capacitors are critical, as the inputs and outputs will be at midpoint voltage. It may be necessary to use another resistor to ground before the coupling capacitor.
Demystifying single-supply op-amp design - 3/21/2002 - EDN
45V will fry the chip. Max of 30V operating, 36V non-operating. Use a zener diode and a resistor to drop the voltage to a safe level for the chip.
Tone control pre-amp digi01 Chip Amps 16 13th June 2011 07:18 AM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 03:12 AM
Tone Control for my GC aditaquil Chip Amps 5 6th January 2005 11:39 PM
TI's Tone control JhonDoe Chip Amps 26 13th July 2004 01:29 AM
Copyright 1999-2017 diyAudio
