I have this:
A TW consisting of a Peerless SDS-164-THP (830657) and a Hivi research X1-A. Crossover: ![]() I want badly to add a supertweeter. The X-1A is a nice tweeter but it's just not punching up in to that "sparkle zone" I want to hear. How can I wire this up? Especially with a minimum to no(?) changing the existing x.o. in the box? What's the best (cheap) supertweeter? I intend to mount it in a separate small enclosure sitting on top of the main cabs.
Wherever you go there you are. |
#2 |
Vifa XT19 is sweet, highest quality and affordable
Vifa XT19TD00-04 3/4" Ring Radiator Tweeter from Madisound Just mount a small cap on XT19 terminal + or - ? I dont know You may need a small series resistor Mounted between cap and tweeter it makes the cap bigger, sort of Within limits you may be able to fine adjust rolloff and precense with this resistor Maybe try it as OMNI, which means the tweeter plays upwards Or try it back mounted Just wire it all to speaker main terminals Or you can try to connect it directly to main tweeter terminals, but may need a resistor in between, but could be more tricky, dont know edit, another one http://www.parts-express.com/pe/show...number=264-735 # Last edited by tinitus; 13th October 2009 at 01:50 AM. |
#3 |
So the cap on the xt19 terminal... series or parallel? I'm guessing it's parallel? then the series resistor between the cap and the tweeter on the pos lead?
What's a good ballpark for resistor value so I know what scale of pot to buy? I'm assuming after I know approx R value I can buy a linear pot to find my fine tuning? This totally bypasses the existing crossover??
#5 |
The small value cap (1uf) should be in series (1st order) with the super tweeter. However, the result may sound super bright so you have to use the t-pad to match the impedance of the existing speaker.
#6 |
#7 |
So do the attenuating resistors go before or after the cap?
#8 |
Depends
Some use a series resistor on both sides of cap I wouldnt use traditional L-pad with paralel resistor Just use series resistor only 1. Resistor between cap and tweeter makes the cap seem bigger, meaning rolloff will be lower than wiithout the resistor Higher impedance results in smaller cap fore the sam xo point Meaning that when increasing tweeter impedance with a series resistor results in slightly lower xo point fore a fixed cap value Theres both pros and cons doing that 2. The series resistor before the series cap is easier to change value without effecting series cap as much 3. All in all this means that with the first resistor you can change attenuation only And with the resistor after series cap you can fine adjust both capacitor, AND attenuation I have doubts about second attached xo Last edited by tinitus; 13th October 2009 at 05:59 PM. |
#9 | |
Excellent tinitus, thanks so much. What do you think my starting values for the resistors should be?
#10 | |
Excellent tinitus, thanks so much. What do you think my starting values for the resistors should be? Also what about this one?
| supertweeter problem | paulfk | Multi-Way | 18 | 15th March 2009 07:55 PM |
| help me choose a supertweeter | SPU_SPU | Full Range | 3 | 3rd July 2006 06:32 PM |
| supertweeter help... | one1speed | Full Range | 12 | 30th March 2006 09:12 PM |
| Adding a supertweeter for FR over 10k | chuck55 | Multi-Way | 5 | 9th November 2005 01:06 AM |
| impedance and supertweeter | xcortes | Multi-Way | 1 | 1st February 2005 12:48 PM |
| Page generated in 0.11512 seconds (79.70% PHP - 20.30% MySQL) with 11 queries |
