Old 12th October 2009, 08:57 AM   #1
thadman is offline thadman  United States
Default Optimal Loudspeaker Beam
Assuming a waveguide is used, a beam of energy is produced. The waveguides direct the energy to a particular shape. The beams produced by waveguides vary (Geddes, Le'Cleach, etc).
What is to be considered the optimal beam shape that these waveguides attempt to achieve?
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them."
Old 12th October 2009, 05:24 PM   #2
brianpowers27's Avatar
Disclaimer, I am no horn guru.
Goal of directivity... To provide good coverage accross the inteded passband to all listeners. Note: Sometimes you want wide coverage but with a woofer matched to a horn you are likely trying to provide a system-wide power response that is smooth through the xo region.
Short answer: There is no single answer to this question. The best coverage patterns are found by simulating the power response of the total system.
[SIZE="1"]--My Speaker building pages http://sites.google.com/site/brianpowers27speakers/
Old 13th October 2009, 06:18 PM   #3
Stereo, Position Independent Stereo, etc recordings require interference between multiple channels and assume a particular distribution of energy (ie a particular beam). This is not subjective, it is what the recording engineers design for.
Old 13th October 2009, 07:30 PM   #4
Robh3606's Avatar
How do they design for something they have no control over?? Speaker directivity is all over the map depending on the design of the speakers. Driver size and bunch of other factors all come into play. So there is no control over what someone hears in their room. There is no set directivity requirements for speakers used as monitors either.
Rob
Old 13th October 2009, 08:14 PM   #5
amiklos is offline amiklos  United States
Is there some requirement in place assuring that they all design for the same condition?
Old 14th October 2009, 12:06 AM   #6
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Some research published at AES showed more beaming in thw lower frequency is desired.
Hear the real thing!
Old 14th October 2009, 02:12 AM   #7
Rob
This is true.
A standard may not exist, however some patterns may produce a more desirable interference pattern with respect to the desired format (stereo, position independent stereo, surround sound, ambiophonics).
I believe Dr. Geddes may advocate consistent 90* dispersion with amplitude decreasing beyond that point to as low frequency as possible. If this is inaccurate or incomplete, I would appreciate feedback.
Phillips described a desired polar pattern for position independent stereo, however I'm having trouble sourcing the article again.
Old 14th October 2009, 02:34 AM   #8
CLS is offline CLS  Taiwan
How?
Mega bass horn, cardioid, or dipole ?
I've never heard cardioid bass, while I do love BIG bass horn and OB bass very much.
Old 14th October 2009, 03:20 AM   #9
soongsc's Avatar
Originally Posted by CLS View Post
How?
It diddn't say how, it only showed analysis results bassed on ITD and IID.
I would love to listen to a Mega bass horn if you have one set up.
Old 14th October 2009, 04:49 AM   #10
Please forgive my ignorance, what are ITD and IID ?
About the big bass horn, here it is:
3way Horn
It's in a big studio of a university in southern Taiwan.
Audio Beam loudspeaker cha11enge Multi-Way 10 14th October 2009 01:27 PM
Tek 475A lost beam shusha Parts 6 11th March 2006 02:16 PM
Page generated in 0.09442 seconds (85.06% PHP - 14.94% MySQL) with 10 queries
