Old 12th October 2009, 08:32 AM   #1
alspe is offline alspe  Finland
Default Boxed woofer + dipole mid/top
Hi.
I'm considering speaker project to start.
Have you seen lot of designs with BR/closed woofer and dipole mids / top, maybe with one fullrange driver? Humblehomemade (modulus) has one and other one I've seen is PFM special.
Humble Homemade Hifi
http://www.roadum.org.uk/BoM-final-revamp.pdf
Some say best of both worlds. I know that biggest room problems are on bass area but still...
Fullrange dipole insist very large cones and distance to back wall. With decent 8-12" woofer BR boxed + tuned to 35 Hz you can make speaker smaller ( higher WAF ) and maybe shorten the distance to back wall. How short it could be if XO is for example 400-500 Hz? With that high XO fullrange can handle louder SPL's.
Of course there is large variation in directivity between boxed bass and dipole mid.
Any ideas of this?
Old 12th October 2009, 10:23 AM   #2
john k...'s Avatar
NaO Mini
John k.... Music and Design NaO Dipole Loudspeakers. "We have no right to assume that any physical laws exist, or if they have existed up to now, that will continue to exist in a similar manner in the future." Max Planck
Old 12th October 2009, 12:36 PM   #3
gainphile's Avatar
Dipole + Monopole never worked for me. They sounded 'off', but my experiments were limited in that area.
Similar to ESL+monopole combination/hybrid. Sure the quantity is there, but...
http://gainphile.blogspot.com
Old 13th October 2009, 11:09 AM   #4
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
No problem with OB mid and boxed bass for me as I've heard several which sounded great. I've listened to plenty built by Andy G and bass quality is exceptional, especially Gumby.
see Andy's Gumby for a great example
I dabbled with it for a couple of years and found the bass driver best crossoved over below 150Hz so it didn't contribute a great deal to the mids. In the end I reverted to sealed mids as the room was not suitable for OB.
I'm an ex bass player and OB bass doesn't sound right with the ones I've heard. Others of course could be completely different.
No longer DIY active
Old 13th October 2009, 07:37 PM   #5
badman is offline badman  United States
Custom Title
badman's Avatar
I agree that it's largely a matter of a low enough XO. It's a crossover, and a particularly problematic one due to the different patterns. If you can get it to a less sensitive frequency band, like <150Hz, you largely avoid the issues.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 13th October 2009, 09:22 PM   #6
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
I would like to take badmans argument a little bit further: Depending on the room size there is a (soft) frequency threshold, beyond which you in fact donīt hear the speaker, but the room modes. There is no iron law that dipoles deal better with room modes than boxed speakers - it is your turn to find the best placement for every speaker. Pushing a speaker to the wall too much will ALWAYS be detrimental - regardless of working principal.
www.dipolplus.de
Old 13th October 2009, 10:18 PM   #7
Andy G is offline Andy G  Australia
Andy G's Avatar
Another couple of similar designs,
Undefinition - DIY - Aethers
Undefinition - DIY - Sunflowers
There's plenty of well designed cases of vented or sealed bass with OB mids/top end.
Acceptable transition freq between dipole panel and boxed sub ? ashok Subwoofers 19 5th June 2009 05:58 PM
Dipole Ribbon tweeter isolation from dipole mid-woofer array Bent Planars & Exotics 5 21st May 2009 12:10 PM
Compromises with a "boxed" dipole speaker mazeroth Multi-Way 8 24th June 2008 07:48 PM
Newbie Dipole woofer help please... santiu Subwoofers 5 30th October 2005 07:20 PM
Dipole Woofer Page BAM Multi-Way 8 8th December 2003 10:49 AM
Page generated in 0.09396 seconds (85.88% PHP - 14.12% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
