Let us suppose, we have 2 arbitrary sources (point,line,etc). They are sent the same signal, however they are separated by a particular distance.
How can we determine a qualitative relationship between the sources with respect to the nearfield? How large can the separation be (wrt wavelength) for them to behave as a single source in the nearfield? to sum constructively, <1/4 wavelength? Thanks, Thadman
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them." Last edited by thadman; 12th October 2009 at 12:24 AM. |
#2 |
that's a hard question.
I suspect that the answer depends on who's listening - is it a point microphone or a head with two ears separated by a distance ? [http://www.icad.org/websiteV2.0/Conf.../brungart.htm]
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#3 | |
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them." |
| Nearfield ribbon? | 8675309 | Planars & Exotics | 5 | 4th August 2007 05:57 AM |
| Nearfield listening | xyrium | Multi-Way | 3 | 10th July 2006 10:35 AM |
| Nearfield Stargate | Magnetar | Multi-Way | 18 | 27th July 2005 02:38 PM |
| re: nearfield monitors | jeantofte | Multi-Way | 5 | 12th October 2002 10:27 AM |
| Need Help Getting Started - Nearfield Speakers | alex douglass | Multi-Way | 20 | 4th October 2001 02:56 PM |
| Page generated in 0.06677 seconds (71.95% PHP - 28.05% MySQL) with 10 queries |
