Old 8th October 2009, 11:31 PM   #1
acold7dusta's Avatar
Default Looking for a good tower project
Hi, I want to build a decent tower (2 or 3 way, doesn't matter) First off, I would consider myself a notice builder, I've built a pair of bookshelves and 5 or 6 car subwoofer boxes. I'm looking for something that extends low enough to not need a sub, sweet midrange, and something that grabs your attention (not bright though). My budget is around $1500 +/- for everything.
It will be for Jazz, Instrumental, Classical, and some Rock
Here are some of my choices (click the name for more info):
Humble Hifi Optimo-very high quality drivers/crossover selection, easy enclosure to make (small footprint also). Never hearing a T-line before, and hearing mixed thoughts make me steer away
Troel's Jazzman-This looks like a great 3 way, and right in my price range. I love the dedicated 8" bass driver, and the style of the cabinet. I cannot find any information of any users of this design, though.
Zaph Audio ZRT
(2 way or 2.5 way) I have heard great success with this design, and the enclosure being available from madisound makes it even more tempting. There's nothing too unique with this (perhaps maybe better for me?) and Im still not sure if a 2/2.5 will be enough bass
Any suggestions? I can always go 2 sp + sub, but id rather avoid it if possible
Old 9th October 2009, 01:13 AM   #2
Default ZRT Endorsement
I am more than happy with my ZRTs. They have been in-circuit for over a year now. Built my own cabinets from baltic birch instead of using Madisound's. Plenty of bass extension. I went with the two-way. The only problem I have is that they are so good I want 3 more for my back and center channels.
Old 9th October 2009, 01:33 AM   #3
The Elsinore.
Thread here somewhere about it.
Old 9th October 2009, 02:50 AM   #4
Good to hear, Cants. Did you stick with the standard crossovers or upgrade?
Old 9th October 2009, 11:22 AM   #5
You might also like the Duet10ss (L26) from Jed at Clearwave Loudspeakers. (www.clearwaveloudspeaker.com)
Old 9th October 2009, 11:36 AM   #6
I would go with a 2.5 or 3-way if possible, it can out-perform 'simple' 2-way speakers on the bass and mid, because of the dedicated mid-woofer and woofer for bass. When a mid-woofer doesn't have to produce the bass tones as well, it'll be much more efficient and clean (less distortion). Using the same woofers in the 2.5 as Zaph does is a nice setup... But if you've got the room/money for a 3 way that troels has displayed on his site, I would definitely go for the latter! And you won't miss a subwoofer with the Jazzman.
Old 9th October 2009, 02:44 PM   #7
"Good to hear, Cants. Did you stick with the standard crossovers or upgrade?"
I went with the standard crossover. Madisound already went to some expense to provide big film caps in lieu of electrolytics. I was a little surprised at the way they surface-solder the connections on the crossover, no through-hole on the boards. I guess I'm a bit old-school and like to see a strong mechanical connection, but I haven't had any problems and they sound great. I went with the two-way because I wanted increased sensitivity, in case I decide to use them in one of my tube circuits.
Old 10th October 2009, 04:40 AM   #8
Thanks for the replies guys, can anyone comment on the sound of any of the posted designs? Characteristics, thoughts, pluses/minus's would help.
Old 22nd November 2010, 07:04 PM   #9
I am the original Jazzman owner, and my opinion may be flawed, but I find that they turned out very satisfying.
Old 23rd November 2010, 04:10 PM   #10
kike01 is offline kike01  Spain
I've build a different version of Troel´s Jazman, using a different twitter (Scan Speak 9900 instead of the original Vifa). I´m very happy with the loudspeaker. The sound is clean, with an extended bass. Those loudspeakers need some space, and they work better into a medium to large size rooms.
I cannot compare with the other designs posted here.
Current Project: Sonaria Tower hongrn Multi-Way 18 20th November 2008 04:54 PM
Focal tower speaker Project pjpoes Multi-Way 25 26th May 2008 11:54 AM
10" driver for Bass tower in Horn project angeloitacare Multi-Way 22 29th November 2007 01:10 PM
Hey, A good <$250 Project gastro54 Multi-Way 32 20th December 2003 04:37 PM
How good is this DAC project??? royalmp2001 Digital Source 5 10th November 2002 06:31 PM
Page generated in 0.11216 seconds (79.31% PHP - 20.69% MySQL) with 11 queries
