Old 7th October 2009, 12:21 PM   #1
sandyhooker's Avatar
Smile routering the truncated design
Many of the "Better Buys" in loudspeakers have truncated flanges which when it comes to making a clean mounting hole presents a problem for me. Using scrap material I've tried to free hand the operation and the results were'nt particularly pretty. There probably is a simple solution which alludes me so I hope someone can point me in that direction. I've made jigs for round flanges but the odd shape stuff is a mystery. Any thoughts???
Old 7th October 2009, 02:53 PM   #2
Bump it
Old 7th October 2009, 05:44 PM   #3
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
If you're speaking of something like the Peerless HDS midwoofers, it might be better to surface mount them anyway.
Epoxy putty for odd driver shapes
Here is a thread describing one method. I have seen a few other threads showing how to use your router with a circle jig to cut truncated round flange cutouts (with just the combination of circular + straight), for other shapes such as octagons with sharp corners, there seems like no easy way to flush mount, unless you just cut out a circular shape, put the driver in place with some tape around the flange, then fill the gaps (similar to how I made my template in my thread linked above).
EDIT: oh, and it would probably be better to wait at least a day before "bumping" your own thread...
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 05:28 AM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 02:07 PM
routering faceplates chainenoble Multi-Way 9 27th October 2006 08:39 AM
Page generated in 0.07330 seconds (71.18% PHP - 28.82% MySQL) with 10 queries
