Hi.
I've been offered an Altec 511 horn for mye speaker project, but it's too wide for me to have space for it. Has anyone tried to use this horn mounted vertically? Like the horn on the JBL Array series. Or has anyone tried other horns, like those big TAD wood-horns or others? Will this work fine, or will I get extremely horizontal dispersion? We sit a lot off-axis here. I'll greatly if anyone's got something to share. Thanks.
http://minhifi.no/Pengvim When Chuck Norris jumps into a lake, he doesn't get wet. The water gets Chuck. |
#2 |
Greets!
Here's its directivity plots where you can see that if vertically mounted it starts out wide and just keeps narrowing up with increasing frequency like a 'full-range' driver, which some folks prefer. There's at least one manufacturer that still uses these vintage horns vertically oriented, but can't find the link ATM. Regardless, just like with 'FR' drivers, toeing them in so that the left speaker is aimed at the far right seating position and vice versa typically works well over a fairly wide arc and you can always add a super tweeter for better HF dispersion/extension if desired. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
| Horizontal or vertical? | dobias | Multi-Way | 7 | 11th August 2009 03:41 PM |
| Altec 811B horns and Altec 414z 12" Speakers | xecluded | Swap Meet | 0 | 21st September 2008 05:21 AM |
| when the datasheet says "vertical mounting: up or down", does it mean... | jarthel | Tubes / Valves | 1 | 2nd November 2006 06:43 AM |
| what is the mounting depth and mounting diameter of this? | lemans23 | Multi-Way | 2 | 26th October 2005 10:52 PM |
| lateral vs vertical,P vs N | Leolabs | Pass Labs | 3 | 15th February 2005 06:01 PM |
| Page generated in 0.06782 seconds (67.33% PHP - 32.67% MySQL) with 11 queries |
