Old 5th October 2009, 09:33 PM   #1
thadman is offline thadman  United States
Default Limits of Human Hearing
Let us suppose an arbitrary individual, Mary, exists.
We ask Mary to assume a comfortable position in a lovely, leather chair we purchased just for the occasion. We also ask Mary to assume a pair of headphones we borrowed from Zeus, which are perfect in every way imaginable (they're Zeus' headphones).
Let us now suppose that Zeus' headphones (which Mary is borrowing) are connected to a computer which functions as a source. If we sent a signal to Zeus' headphones, Mary perceives this as sound (we assume her ears work).
If we sent Zeus' headphones 2 signals, which possess the same frequency content but different amplitudes, what would be the limit of Mary's hearing where she could no longer differentiate between the two signals?
1dB? .1dB?
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them."
Old 5th October 2009, 10:03 PM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
Try it, Mary. ILD perception most likely depends on bandwidth...
http://en.wikipedia.org/wiki/Sound_localization
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 5th October 2009, 10:33 PM   #3
What is the limit of the human auditory system?
Originally Posted by Master Handbook of Acoustics
The silence presses down on you in the tomblike silence, 10 min-
utes, then a half hour pass. New sounds are discovered, sounds that
come from within your own body. First, the loud pounding of your
heart, still recovering from the novelty of the situation. An hour goes
by. The blood coursing through the vessels becomes audible. At last, if
your ears are keen, your patience is rewarded by a strange hissing
sound between the “ker-bumps” of the heart and the slushing of blood.
What is it? It is the sound of air particles pounding against your
eardrums. The eardrum motion resulting from this hissing sound is
unbelievably small—only 1⁄100of a millionth of a centimeter—or 1⁄10
the diameter of a hydrogen molecule!
How can we quantify this expression?
Old 5th October 2009, 10:58 PM   #4
SY's Avatar
The usual engineering unit is the RCH.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 5th October 2009, 11:02 PM   #5
Old 6th October 2009, 08:21 AM   #6
breez is offline breez  Finland
1dB? .1dB?
Depends on signal content. And what is meant by differentiating between the two signals? Usually a single auditory event is heard, but it is displaced from the center of the head towards either side. You could look up lateralization blur which means the smallest change in interaural level difference leading to a lateral displacement of the auditory event.
Old 6th October 2009, 09:10 AM   #7
pheonix358's Avatar
You also need to take into account that our perception of sound is log not linear. Therefore if the noise floor is low you here more subtle sounds. But if your trying to work out if the left turbo prop is louder than the right one, good luck.
Terry
What we don't understand is called magic.
Old 6th October 2009, 09:50 AM   #8
1 db
Old 6th October 2009, 10:48 AM   #9
pheonix358's Avatar
Originally Posted by mscommerce View Post
1 db
Can you tell the difference between 145 and 144dB. I can't. It is never so simple. We havn't even talked about the difference between Conceptual Vs Factual brains. They are different.
Terry
Old 6th October 2009, 11:02 AM   #10
Warp Engineer
On Holiday
AudioFreak's Avatar
The textbook would probably say 1dB but it is highly dependent on the situation. In some very limited situations a very good and well trained set of (human) ears / brain can differentiate between 2 levels less than 1dB apart but in most everyday situations it will probably be closer to 3dB or worse.
- Dan
Sensitivity of human hearing retroman Multi-Way 49 7th July 2009 10:31 PM
Distortion of human hearing PMA Everything Else 44 22nd April 2008 11:21 PM
Harmonics above 20Khz - "Hi-Fi" and the limits of human hearing percy Everything Else 62 12th March 2008 05:27 PM
Human Hearing................. Gavinator68 Everything Else 25 26th January 2006 02:15 AM
human hearing sss Solid State 123 8th September 2003 07:57 PM
Page generated in 0.10480 seconds (80.27% PHP - 19.73% MySQL) with 10 queries
