Hi all,
I've been debating what to make with a pair of Klipsch K-33 woofers I have.
The specs as provided by eminence are,
SPEC 15162
PART # K-33
RE OHMS 3.39 FS HZ 34.46
LE MH .96 MMS GMS 78.59
QM 7.39 CMS mm/N .2714
QE .410 RMS NS/M 2.3037
QT .390 VAS LTRS 301.66
XMAX MM 8.20 SD SCM 889.59
BL TM 11.88 EBP 84.4
EFF % 2.91 SPL dB 96.6
Wattage 150rms
I'm trying to figure out if these would work well in an Onken style enclosure.
I've typed the specs into the onken spreadsheet I found on the internet and things such as vent length seem to stay within spec for the onken ideal.
My other option for these woofers is the klipsch MWM folded horn.
But I'm really curious about the onken.
Any thoughts and ideas?
Thanks,
Josh
SPEC 15162
PART # K-33
Wattage 150rms
Thanks,
Josh
