I bought some 44's, loved them for an evening, went to replace the silly speaker terminals in the morning, and found a chanel had gone. A very faint and distorted sound is all thats coming through. I've tested the speaker cones and they are all fine, the signal from the amp is good also. My only guess is that, as they were left unused for some time, that a capacitor has gone. I would love to replace them all anyway, but I am no tec' head, and I am on a tight budget.
I desperately need some advice about what sort/make of capacitor I can look to replace the old ones with. There are some replacement crossovers on e-bay, but I think it might be unwise to replace the boards with another set of old caps.
Could I take the capacitor specs to RS, and just replace them directly with modern units, not designed with the audiophile in mind?
Would be most grateful for any help - have no hi-fi - going mental.
Make sure that you get non-polarised caps (sometimes called bipolar) and match the capacitance and working voltage.
What are the markings on the old cap?
BTW, how did you test the speaker cones?
edit: it may be prudent to test the caps. If the cap has indeed gone high impedance then you should be able to measure a higher AC voltage across it compared to the good speaker when playing music. Do you have a meter? I've spent too much money doing the "trial-and-error" fault finding technique.
I helped Lorien replace his binding posts last night, so I've seen inside the speakers, and I did test the board a bit by bypassing caps with a wire, but couldn't isolate the offending item.
We tested the speakers by wiring each one in turn to the direct signal at a fairly low volume. All of the drivers are sound.
At 30 odd years old it seems prudent to me to replace all of the caps, even if for the pocket's sake it need be with the non-exotic types. I think that standard modern electrolytics, for example, should blow these old ones away, right?
I have a meter. To test a cap, do I place the terminals across the cap? Will AC voltage be consistent, or vary with music? I ask because whenever I've tried to multimeter music signals, my reading jumps around like it's gone mad. I don't really know how to use it properly.
Lucas
Lucas
I tested the speakers individually bu introducing direct feed from the amp at low volume. All responded. Secondly I ran the positive from the primary conection point on the cross over, then traced backwards from the primary negative connection. This produced a selection of music at different frequencies from individual cones/tweeter. Common sense seemed to indicate that the first cap had gone, but I couldn't make sense of wyh that only produced sound from one speaker when I took it out of the loop.
My gut tells me to replace the lot so this is not an experience I have to repeat. I've bought a rogers cadet 3 to play them on, and I'm hoping for a long stretch of trouble free pleasure with the set up. I am a little concerned that simple, non audio, though properly rated caps will return less sound quality than the tired old ones. Do you think this is the case - or will modern replacements do the job well.
Many thanks - LB
Many thanks - LB
It's very likely that a 20yr old cap has dried up and gone high impedance and yes, modern electrolytics are much better (must be non-polarized of course.) But what's the evidence of that here? I don't advocate replacing any components just because, especially if there's a few non-invasive tests you can do to test your assumption, it could save time.
Where is the suspect cap in the circuit (across the woofer, in series with tweeter?) and how does the AC voltage compare between the good and bad speaker. Because a cap passes AC, there should be little or no measurable AC voltage across it (unless you got a deep bass music passage). If it has gone high impedance you will see lot's of bouncing around with occasional large numbers as you described.
Any photo's, schematics?
hope the pic arrives!Here is a pic' of the cross over. All of the solder seems to be good and there is no visual hint as to any fault. Might there be another reason for the failure?
Many thanks for you time and help - LB
Look here
Lorien,
Search and find the Thread in this Forum titled :-
celestion 66 needs Mid-range
started by:-
Mr_White
There are many pages in it and a lot about restoring old Celestion speakers of the vintage of yours is discussed,
including plenty on replacing the capacitors for cases where one actually wants the speaker cross-over to work
in the manner it was originally designed,
plus have the audible improvemments capable with carefully chosen modern capacitors.
Lorien,
started by:-
Mr_White
That orange electrolytic on the top looks a bit out of place. Do you think someones worked on it before?
Do you have access to some kind of signal generator? If not, there's apps for the PC that will create tones of different frequencies as .wav files. You could put together a CD with different tones on to help debug.
Taking voltage measurements across the caps with different frequency tones should reveal the problem. 80Hz, 800Hz and 3KHz will work. If you trace out the components and connections you should be able to reverse engineer the schematic.
Just had a thought.
You could test all the caps in this with a 9V battery & a meter. Depending on the meter resistance (which should be huge) all the caps should hold up a DC charge for several minutes if they truly are still caps.
Disconnect the speakers and hook up a 9V battery to all the terminal pairs in turn. Watch each cap discharge in both polarity.
rebuilding celestion ditton 44
hi,sorry for my little english and long time for your question ,i have rebuilt a pair of ditton 44 find in trash ,i have repair the cabinet with many damage with new wall wood and new veneer and repair one midrange with a little cable interrupt and totally recap the crossover (after 40 years old the capacitor very bad value) if you dont have resolving your problems post me if is all well good listening and regards Osvaldo
more about Celestion 44 here
Hi Osvaldo,
you "find in trash" !
You are very fortunate - I wish I could find someting that good in trash !!
{I did find B&W DM 110 in trash, but those are not as good as Ditton 44.}
There is more about the Celestion 44, and some upgrades that owners are considering, in the Thread titled:
Crossover nightmare!!!!!!!
also started by:- lorienblack
Is the baffle {front panel} of your 44 exactly as you found it,
or did you cut away wood edges of the side panels which extended past the front edges ?
Hi Osvaldo,
total rebuild celestion ditton 44
hi,sorry for my little english ,i have find in trash a pair of this cabinet very damage, water destroyed down of box scratch terrible and a little frame destroyed and one tweeter brokken i have cut the bottom and replacement and cut little frame front and to fill every hole smoothing all,after new veener wood and buffing wax new tweeter buy in ENGLAND 60 euro damned and recap crossover 30 day of work but now ihave a new pair of this thanks and regards Osvaldo if you wont i can post a photo of this in a forum or to you
- Celestion ditton 44's - capacitor GONE!! Help!!
