Hi there,
Just picked up a pair of PSB Passif II speakers, foam on the passive radiator needs replacing, not too big a deal. A suggestion on where to get the replacement foam might help though. Where there is a bigger issue is in one of the woofers. On one speaker I noticed that one woofer wasn't working. I took it out of the enclosure, hooked it up directly to an amp. I got it working when I jostled the wires going to the voice coil. Any ideas on how to fix it? |
#2 |
Resolder the wires to the terminals.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
I tried putting the wire from the amp directly on the wire (bypassing the outside solder connection) I have a feeling that the loose connection might be on the inside of the woofer....any idea's if that is the case?
#4 | |
It could be resoldered if you can get to it.
#5 |
Never done that before, is it a matter of cutting off the dust cap and getting right into the middle of it?
#6 |
If the coil has broken then its probably best to get a recone kit or just replace the driver.
| intermittent DC in PL400 | Othello | Solid State | 10 | 27th June 2009 01:46 PM |
| intermittent hum | balance | Instruments and Amps | 4 | 17th December 2008 01:01 AM |
| Can IC's have intermittent faults? | pedroskova | Parts | 5 | 6th December 2006 11:19 PM |
| Intermittent PA amp problem | pjpoes | Everything Else | 2 | 15th October 2005 10:36 PM |
| Amp is intermittent | DD_Davo | Chip Amps | 23 | 3rd April 2005 01:42 PM |
| Page generated in 0.11325 seconds (60.87% PHP - 39.13% MySQL) with 10 queries |
