Old 28th September 2009, 12:41 AM   #1
DreadPirate's Avatar
Default "Generic" 8" Sized Replacement Thin Wall Woofer Surrounds
I'm looking for a foam surround that is generic 8" in size (15cm cone diameter) with the thinwall such as is found on the proper replacement foams for the Large Advent woofer. Basically, a much more compliant replacement surround than is usually found in the 8" size.
Old 30th September 2009, 06:05 PM   #2
Hi Dread,
You could check out Parts Express - they have some fairly thin foam types that I used to repair some old Paradigm's one occasion. Did you mean thin in terms of material or width of the roll?
Jim
Old 30th September 2009, 07:15 PM   #3
I mean thin in terms of material thickness. The Snell E/III surround, though exactly 8" generic dimensionally, is much more compliant than the standard generic foam. It's quite thin, like the proper Large Advent surround if you're familiar with that product. Snell is not helpful with the replacement.
Old 30th September 2009, 07:40 PM   #4
Godzilla's Avatar
Is it possible you may be looking for a low Qts driver that's very springy to the touch?
Godzilla
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
WTB : Pair replacement foam surrounds for Tannoy 315 12" HPDs tekno.mage Swap Meet 5 21st September 2008 02:42 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
Generic "Open" Chassis Design Effort ... TVP Chip Amps 0 11th January 2005 04:08 AM
Looking for a "thin" center speaker design m1abrams Multi-Way 18 30th May 2004 07:05 PM
Page generated in 0.12422 seconds (43.72% PHP - 56.28% MySQL) with 10 queries
