Why in the world do you never hear of high density particle board being mentioned for speakers -- but always MDF?
Cabinet makers wouldn't dream of using MDF. HDF is much heavier, machines much better. It's also called "cabinet grade". Is there something (other than weight) that deters it from being used? (or even mentioned?). |
#2 |
I guess it is just a little harder to get at the local home center.. HDF does make sense for speaker construction and some manufacturers do use it. (My former mid-fi employer used it during the time I worked there.)
www.kta-hifi.net |
#3 |
I think MDF became popular with the big manufacturers due to improved sound as a result of different damping characteristics compared to the other boards that were available at the time.
We had lamin board and block board, plywood, particle board, hardboard (<6.3mm as far as I recall) and a few others. note that "heavier" and "machines better" and "cabinet grade" do not have any "sound quality" attributes.
regards Andrew T. |
#4 |
...truth seeker...
I would love to use HDF...I've looked for it...can't find it "local" to zip 40403.
Maybe you are close enough across the river to share a source? Is there one in Louisville/New Albany?
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#5 |
sometimes 'Ranger' board is available at lumberyards, at least here in Canada. it's a premium version of MDF. i get my HDF from a local cabinet maker that keeps quite a bit in stock.
david |
#6 |
In Europe at least, "HDF" is the same as high density MDF. I prefer the moisture resistant type of MDF which is very heavy and dense.
#7 |
Mmm, here in the Netherlands, you can find HDF, except it is also called MFD. I found that there is a lot of 'difference' in MDF at local diy-woodshop. I found one that has the HDF grade and sells it under the name of MDF....
And indeed, MDF is a real problem with a router, HDF is just a lot easier; so less faults in the wood while cutting at high speed. |
#8 |
HDF is obtainable in speaker cabinet thicknesses in my neck of the woods, but the price makes using real wood MUCH more attractive
![]() Cheers! |
#9 |
So, what about the sonic performance of HDF vs MDF? (or are there any)?
It's not that much more expensive -- I get it at a local hardwoods place. The stuff weighs a ton. |
#10 |
Ed --
Call a cabinet maker, I'm sure it's available in Louisville -- he may even have cutoffs. I know a counter top guy that loves to give away his scrap. Including CORIAN. |
| Page generated in 0.12967 seconds (70.11% PHP - 29.89% MySQL) with 9 queries |
