Old 24th September 2009, 01:04 PM   #1
Default PLLXO implementation
Afternoon all, (well it is for me anyway!)
i want to use a pllxo to cross over to my sub (2nd order-80hz)
im a little stuck though as i have my speakers tri-amped.
using this guide-im stuffed as i dont know wha to put in as a value for the high pass amp impedence- can anyone help me?
thanks people
Old 24th September 2009, 01:05 PM   #2
appologies- heres the guide http://www.t-linespeakers.org/tech/f...ssiveHLxo.html
Old 24th September 2009, 01:52 PM   #3
picowallspeaker's Avatar
May be that you'd feel uncomfortable with "big" capacitor values shunting to ground ?
Old 24th September 2009, 04:31 PM   #4
its worth a go either way i think.
Old 25th September 2009, 04:53 AM   #5
if your 'R2' to ground is small enough, say 10K or less, the imput impedance is unlikely to have much effect...
(i.e. just make R1=R2)
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 25th September 2009, 05:27 AM   #6
Ipanema is offline Ipanema  Malaysia
Ipanema's Avatar
May I know why C2=C1/10 and R2=10R1? Can I use like C1=C2 and R1=R2 since they will have the same -3dB frequency. Thanks.
Old 25th September 2009, 05:44 AM   #7
Andrewwwww T ! Where are you ?
I think it's the Time Constant that had to be taken in consideration
Old 25th September 2009, 05:45 AM   #8
sorry guys, I was talking about the 1st order circuit,
R2 in the 2nd order schematic will be effected much more by the following input impedance if it's 10xR1
Ipanema, follow the link to Art Ludwig's site on the t-line speakers page link above if you want the gory details of the maths...
Old 25th September 2009, 07:07 AM   #9
Ipanema's Avatar
In the example given for second order filter with equation f=1/2*pi.*R*C,
f=1kHz: R1=5 k W, R2=50 k W, C1=31.8nF, C2=3.18nF
and I will still get the same f even if C1=C2 and R1=R2, where
f=1kHz: R1=5 k W, R2=5 k W, C1=31.8nF, C2=31.8nF
I would appreciate if anyone can explain to me why Art Ludwig's prefer C2=C1/10 and R2=10R1. Thanks.
Another note is the above equation is only accurate assuming that source output impedance is 0 and the stage after filter input impedance is infinity for HPF.
Old 25th September 2009, 07:44 AM   #10
frugal-phile(tm)
planet10's Avatar
This configuartion is to not have the secound stage loading down the 1st stage.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
PLLXO (v AXO v PXO) benefits/ Model? rick57 Multi-Way 42 9th August 2011 11:12 PM
Anybody interested in checking my PLLXO? kirk57 Analog Line Level 6 4th December 2009 02:18 AM
Calculate PLLXO audiobomber Multi-Way 5 22nd August 2007 05:34 PM
Using phono input with PLLXO mashaffer Subwoofers 0 13th August 2007 11:36 PM
PLLXO high pass Soulwax Multi-Way 8 6th May 2005 12:40 AM
Page generated in 0.14766 seconds (62.39% PHP - 37.61% MySQL) with 10 queries
