Looking for measurements that any of you may have of horns and waveguides near their low cut-off frequency.
Standard practice is to high pass the horn at least an octave above its cut-off frequency. Is this really needed at home hi-fi levels? Some say no. So if you have phase, distortion and impulse measurements that you would like to share, please do. Let us know what the horn and driver are, if you can. Also point out what you think are the important parts of your measurements. Actual measurements are vastly preferred over simulations here. Simulations are OK if you can also show us the real measurements. It will be interesting to see what horns are really doing down there. Thanks! |
#2 |
Here's a 1 inch JBL 2425H on a JBL 2307 Exponential horn. It's a 1.2K horn so the sweep starting at 200Hz is well below cutoff. The red is the THD reading for the measurement.
Rob |
#3 |
Wow! As I can see the FR extends well down to 500Hz! And they call that a 1.2kHz horn? Also, the distortion below cutoff isn't any worse. Am I missing something?
#4 |
I'll see what I come up with. I'm doing some work with a different type of tapped horn. I've listened to the baby one for over a month and it does distort below cut off. But I'll do some actual carefull measurements on the bigger brothers. It'll be interesting.
Mark
Mark |
#5 |
Agreed, looks odd to me as well.
#7 |
Here's a JBL 2370 Flat Front Biradial with a 2426 1 inch driver. Lowest loading to 630Hz
Rob |
#8 | |
Rob |
#9 |
Hello,
We have to take care to how such mesurements are presented. What we see is that the "absolute" THD curve comes nearer to the response curve (passing from 40dB = 1% at 1kHz to #-20dB = #0.1% at 200Hz) when the frequency decreases below the cut-off. This indicates a 10 times rise in the distortion relatively to the "fundamental". (For further decreasing frequency there will be a frequency for which the THD curve will cross the response curve, at that pont THD will be 50%...). Another important curve to consider is IMHO the group delay curve of the horn. Best regards from Paris, France Jean-Michel Le Cléac'h Last edited by Jmmlc; 23rd September 2009 at 12:12 PM. |
#10 |
Augerpro has done testing on many horns/waveguides this last summer.
http://www.htguide.com/forum/showthread.php4?t=33682 QSC Waveguides are cheap and impressive. |
| About first cycle distortions and memory distortions | gaetan8888 | Solid State | 3 | 11th November 2007 07:15 PM |
| ESL distortions ? | JinMTVT | Planars & Exotics | 2 | 25th November 2006 12:09 PM |
| Phase plug for cone driver in mid-bass horn design? | mefistofelez | Multi-Way | 2 | 18th October 2003 07:59 PM |
| Page generated in 0.20899 seconds (51.37% PHP - 48.63% MySQL) with 11 queries |
