Old 20th September 2009, 05:21 AM   #1
Default Speaker cabinet impedance concern.
I recently loaded a 4x12 cabinet with 16 ohm each speakers. My goal was to get the cabinet to 4 ohms, so I wired two of the 12's in parallel and the other two in parallel and then the met the two pairs at the input jack of the cabinet. So two positive ( one from each set) meet at the tip terminal of the jack and the two negative (one from each set) meet at the sleeve of the jack. Should be 4 ohms right? they are all in parallel at this point. Well, I measured the resistance with a multimeter to get an impedance close to 4 ohms but it is reading 1.8?
I realize that multimeters measure dc resistance but doesnt this seem too low? I am running a vintage 4 ohm tube amp through this cabinet and I dont want to put any strain on the output transformer. Any help or insight?
Thanks, TTH.
Old 20th September 2009, 02:00 PM   #2
edjosh23's Avatar
Measure the DC resistance of the drivers individually. As you know the RE of a driver is quite a bit lower than the impedance. According to your 1.8Ohm measurement a single woofer should be ~7.2Ohhms, which is much more like the RE of an 8Ohm driver. You did connect everything properly if I understand everything properly.
Good luck,
Josh
Old 20th September 2009, 02:38 PM   #3
It is not always the case that the re is close to the stated impedience. I have a pair
jbl 2123j drivers this is a 16 ohm driver the re is 8.7ohms the same driver in the 8 ohm
version jbl2123h has a re of 4.2 ohms I took these figures directly from the JBL professional web page.
What creates the impedance peaks in ported cabinet? teemuk Multi-Way 1 26th February 2007 09:01 PM
A Grounding Concern Code Parts 4 26th January 2007 10:26 AM
Thermal management: it this not really of concern? LowRedMoon Tubes / Valves 18 16th November 2006 01:11 AM
Is power compression a concern with tweeters? noah katz Multi-Way 5 27th December 2005 06:18 AM
Time Travel....a concern not really mentioned Hybrid fourdoor Everything Else 14 17th July 2004 01:28 PM
Page generated in 0.14822 seconds (38.16% PHP - 61.84% MySQL) with 10 queries
