For the design of a cantilever, assuming a Hookean material is used below its proportionality limit, stress will be proportional to strain. From this we can conclude that its behavior will be linear.
However, how can we apply this knowledge towards helical springs? Is it possible to design a helical spring whose linearity approaches or equals the cantilever? Thanks, Thadman
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them." |
#2 |
Depends on how close you want to approach it.
I think the only significant linearity in a helical spring is change in the helix angle with displacement, but I suspect it's minor for any realistic spring. What's the application?
----------------------------------------- Noah |
#3 |
Assuming a cylindrical, uniform, helical spring, whose coils have not started to close, which supports a surface. Would the spring force be linear across the contact surface?
#4 |
Depends on the surface shape; if it matches that of the undeflected spring, I'd think not, and the force would be concentrated at the latest point of contact.
If it's flat maybe, but it may need to be some other shape.
----------------------------------------- Noah Last edited by noah katz; 19th September 2009 at 11:17 PM. |
#5 |
I picked up the seventh edition of Roark's formulas for Stress and Strain. It appears to be rather trivial to calculate the fundamental resonance for a helical spring (f(n)=1/2sqrt(k/m), where k=spring constant and m=mass). However, calculating the mass normalized modes does not appear to be trivial.
How should we approach solving this problem?
#6 |
The engineering section on a spring company's (try Associated Spring) site should have formula for res freq.
Again, what's the application? You could really step out of the box and try google.
----------------------------------------- Noah Last edited by noah katz; 21st September 2009 at 08:09 PM. |
#7 | |
Let me be more explicit, Assuming a cantilever (left end fixed, right end free), an equation exists which defines all of the natural frequencies. F(x)=(K(n)/2pi)*sqrt(EIg/wl^4) Where K(n) = 3.52 for the 1st mode (n=1), 22 for the second mode (n=2), 61.7 for the third mode (n=3), 121 for the fourth mode (n=4), 200 for the fifth mode (n=5), etc. Nodal position wrt length = .783 for the 2nd mode (n=2), .504/.868 for the third mode (n=3), .358/.644/.905 for the fourth mode (n=4), .279/.5/.723/.926 for the fifth mode (n=5), etc How can we define a similar equation for a helical spring?
#8 |
"Again, what's the application?"
You won't answer that question, so let me ask you this - why are you posting this here?
#9 | |
If we acquire a complete understanding of the system, qualitative logic can be exploited. For example, the electric field within a uniformly charged sphere is 0 due to symmetry. However, if we were to observe a charged rod of uniform cross section with an arbitrary length, it can only approach infinite linearity (with regards to the field), it will never achieve it. I find (as demonstrated in example 1) systems which equal a value (rather than approach it) deeply fascinating. Why do I post on this forum? I feel this community is highly educated, open-minded, and mature. Intelligent discussion benefits the community, ideas/concepts become more accessible to those with an incomplete understanding and those ideas/concepts reach a higher resolution through debate.
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them." Last edited by thadman; 21st September 2009 at 08:56 PM. |
#10 |
Yes, I was a bit annoyed by the one-wayness of your inquiry.
| want to buy reverb springs | akis | Parts | 4 | 27th July 2009 07:28 PM |
| Linearity | maxpou | Solid State | 42 | 8th February 2008 10:44 PM |
| helical horn sub? | Ang | Subwoofers | 0 | 13th January 2007 05:34 AM |
| Seeking AR XA suspension springs | Alter Ego | Swap Meet | 0 | 20th March 2005 03:20 PM |
| Thorens TD150 and Linn springs | Zombie | Analogue Source | 4 | 16th July 2004 09:32 AM |
| Page generated in 0.16116 seconds (57.81% PHP - 42.19% MySQL) with 10 queries |
