I'm not sure if this question belongs here as I have little to no experience in such things... I have a pair of Usher s520 speakers, on which I would like to reduce the volume outputted by the tweeter. I find the tweeter a bit too obvious and would like to "pull it down" a bit without changing its sound. Is this possible without opening the speakers by connecting a resistor across the terminals on the back or some such solution? Any suggestions or advice would be very welcome! Thanks |
#2 |
Try mount a piece of thin single layer toilet paper in front of the tweeter
Doesnt look good But if you use front cloth its no problem Last edited by tinitus; 19th September 2009 at 10:22 PM. |
#3 |
For experimentation, maybe you could try bi-amping and controlling your tweeters that way.
Martin + + |
#4 |
I have the same speaker and biamping let me control the amount of tweeter volume.
#5 |
Unfortunately Bi-amping is not an option for me. Id also rather not resort to a piece of toilet paper!
I was reading about L-pads and wondered if I could use one of the L-pad calculators on the internet to give me resistor values and then connect one between LF and HF terminals on the back of the speakers and one between the + and - HF terminals? Would that work to reduce tweeter volume? |
#6 |
Those speakers are bi-wireable, correct? I would try removing the strap between the two plus inputs and connect a 1-2 ohm (a few watt) resistor in its place. (Make your speaker cable connection to the woofer inputs.)
That will pad your tweeter minimally and effect the crossover minimally. Give that a try. Cheers, Dave. |
#7 |
Excellent, that sounds simple and cheap to try! Is it not necessary then to connect another resistor between the tweeter's binding posts? I read on a few websites that if you just put a resistor in series then you will effect the crossover frequency.
#8 |
Actually when connecting the speaker with one set of cables to the woofer terminals would it not be incorrect to place a resistor in parallel with the tweeter terminals? In this case would the resistor not be in parallel with both speaker drivers and effect both rather than just the tweeter? My circuit theory is a bit rusty....
#9 |
http://www.sengpielaudio.com/calculator-Lpad.htm
If you put the resistor before the xover components you won't affect the xover freq
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#10 |
That solves it
Hmm, maybe thats the point of having biwire terminals ![]() Lets us know how it turns out Last edited by tinitus; 20th September 2009 at 11:32 PM. |
| Usher 9950 tweeter | Bill Fitzpatrick | Multi-Way | 19 | 19th July 2010 07:49 AM |
| Reducing volume of planar tweeter | tubesmuggler | Planars & Exotics | 3 | 17th November 2008 05:52 PM |
| Reducing output of tweeter | bawang | Multi-Way | 2 | 16th November 2006 01:27 AM |
| Reducing volume? | barendh | Solid State | 16 | 5th September 2006 02:00 PM |
| Usher 9950-20 Tweeter | JCD | Multi-Way | 1 | 20th September 2005 09:27 PM |
| Page generated in 0.55937 seconds (18.40% PHP - 81.60% MySQL) with 11 queries |
