Old 19th September 2009, 04:05 AM   #1
Default Peerless MTM ?
Hi everyone !
Can someone suggest a tweeter for my peerless 830657, I have a bunch of them sitting in the garage. I am now planning to build a pair of cheapy MTM or possibly something like MTM-MM. Better yet, does anyone know of any proven project plan with this Peerless driver?
Thanks in advance...
Old 19th September 2009, 06:51 AM   #2
Default If you can find them on ebay at a low price
http://www.zaphaudio.com/oldversions...55-2006-FR.gif
D26NC-55-06
Or go to madisound.com and get these
DQ25SC16-04 at a great price and a very good choice
or if you are willing to spend a bit more these
part express
Tang Band 25-1719S 1" Ceramic Dome Tweeter
Vifa D27TG-05
Old 19th September 2009, 11:23 AM   #3
hasaudio.co.nz's Avatar
the d26 is quite well regarded.
Hasaudio Speaker Components
Old 20th September 2009, 12:28 AM   #4
I made one peeless mtm but with 830656 drivers matched with a tweeter Seas 27 TBFC/G; Fx 1.7khz, quite simple x-over, these drivers ar easy to work with, I guess 830657 should be as simple to filter. Sorry, in french but pictures are without frontiers, isn't it?
http://www.homecinema-fr.com/forum/v...055&t=29915162
crazyhub
Old 20th September 2009, 02:19 AM   #5
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
I don't recommend the TB Ceramic tweeter. I tested several and the breakup that they show to be above 20Khz we measured to be below 17Khz. Also, the cone seems to be anodized Aluminum, not ceramic. Though, I suppose you could technically call the very thin coating of Aluminum oxide a "ceramic" it seems far from honest.
The smaller of the two peerless woofers mentioned in this thread so far looks like it has an easier response to work with IMHO. The larger one seems decent, just a little trickier to make the crossover, perhaps?
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
Old 20th September 2009, 07:10 PM   #6
Thanks guys !
Would the Vifa D27tg4506 be a good choice to mate with the peerless 830657in MTM+MM configuration ? At a freaken $37.25/ea plus tax at Solen in Montreal, Canada....
I did some research on some Peerless HDS driver and found the "Elsinore Project" I can't believe the Elsinore could worth as much as 20 grands ! Take a look : www.customanalogue.com/.../elsinore_index.htm
Anyway, my SLS 830657 do indeed have the same HDS 830875 look (well kind of...except the cone and cast frame...) but the response graph, well...look almost the same...you see that the thing with Peerless speaker, is that no matter if it is the HDS with nomex cone or the cheapest SLS with paper coated cone, you still get great perfomance driver.
So I think I am going to try to build one of those really cheap Elsinore clone with the SLS driver and see how it will sound.
Having say that, here is a begging request for someone with expertise in filtration of frequency. Could you be kind enough to model one up for suggestion ?
Thanks in advance !!!
Peerless vs Peerless, a 10" infrawoofer Telstar Subwoofers 13 24th November 2009 07:20 AM
peerless xxls sealed -vs- peerless xls with passive radiator Naudio Subwoofers 8 23rd March 2008 09:00 PM
Sub with peerless sls-10 testarossa2k Subwoofers 24 23rd August 2007 09:12 AM
WTB:Peerless bhg41088 Swap Meet 1 6th July 2004 10:41 PM
Whats the difference between the Peerless 831916 and Peerless 850122 SkinnyBoy Multi-Way 9 12th June 2003 03:11 PM
Page generated in 0.12010 seconds (63.41% PHP - 36.59% MySQL) with 10 queries
