How to choose active XO freq? - diyAudio
Old 15th May 2003, 10:25 AM   #1
Default How to choose active XO freq?
Having been inspired by Rod Elliots article on Bi-amping I have decided I am going to build an active crossover for my Mission 703e s. The only problem is I don't know what crossover frequency to use. Does anyone know where I might find such information? Or if there is a way of calculating it?
Any info is much appreciated
jnxw2
Old 15th May 2003, 11:25 AM   #2
Raka is offline Raka  Europe
Raka's Avatar
Default Good question
I think you are doing a good thing.
Is not difficult. Are they two ways?
You should find out which is the crossover point based on the crossover parts and impedance of the drivers.
Would be even better if you could measure the drivers, that would be very good, because then you could choose the trade-offs and not the original designer.
Any info about the speaker?
Which filter do you plan to use?
My modest knowledge is at your service
BTW the esp article is very inspiring
What is beyond the speaker?
Old 15th May 2003, 11:30 AM   #3
Andypairo's Avatar
The starting point can be the present XO frequency set by the passive crossover, anyway bi-amplification implies that you open your speaker and bring outside speaker terminals directly, completely eliminating the passive xover; if the speakers allow bi-wiring you can take advantage of the double terminals, otherwisa you need to find a solution.
Cheers
Andrea
Old 15th May 2003, 12:50 PM   #4
MadMax is offline MadMax  New Zealand
You can use a sine wave generater like in winisd the xo point is when output is even from both drivers, this will give you a starting point then use your ears and wot test equpment youve got. Take your time and do a few times write things down as you go. good luck Max.
Old 15th May 2003, 01:09 PM   #5
In fact I made a mistake they are not 703e but 773e s
The cones are approximatly 10.5cm or 4in in diameter. I am not sure though if they recieve the same signal or if one does mid and the other does bass??
The speakers have two sets of terminals and I have already taken the passive XO out to have a look, unfortunatly the value of the inductors isnt marked on it. I dont have my digital camera with me but i should be able to post a picture of it tomorrow if that would help.
cheers
jnxw2
Old 15th May 2003, 01:23 PM   #6
jackinnj's Avatar
Default hold on there
when you start from scratch you usually have some semblance of the response curve of the driver from the manufacturer -- I did say "semblance" since the conditions are often ideal which isn't what you will experience at home.
One thing which I have been thinking of doing is a "State Variable" filter using digital pots to set the low pass, band pass and high pass filters -- one could adjust the performance on the fly by adjusting the digital potentiometers.
Analog Devices has one such design on the PDF for their dual 8-bit DAC, but, of course, you could use a digital pot from Analog, Dallas (Maxim) etc.
Old 15th May 2003, 01:38 PM   #7
On Hiatus
SY's Avatar
Don't try to second guess a good designer. The electrical crossover may not be (probably will not be) a simple, symmetrical function. Get in there and measure the electrical transfer function of the crossover at each of the driver terminals, then design the electronic crossover to duplicate it. Otherwise, you'll end up with a speaker that sounds different but almost certainly NOT better.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 15th May 2003, 01:48 PM   #8
im pretty new to this, is there an easy way to measure the electrical transfer function of the crossover with a DMM and sinewave generator?
jnxw2
Old 15th May 2003, 02:27 PM   #9
On Hiatus
SY's Avatar
If your DMM has a spec'd frequency response that's flat out to 10kHz or so, then it's a piece of cake (though a bit tedious)- feed the signal generator to your amp, adjust the volume to something reasonable (not too loud, not too quiet, something on the order of a couple of volts), then measure the voltage at each driver terminal at a number of frequency points. Plot the results for each driver on a log-log graph, and you'll have a good idea of what the crossover will have to do.
If your DMM is not spec'd to be flat over the audio range, borrow an oscilloscope or an AC voltmeter. Or get serious and use some MLS or FFT software and do it with your computer. This will give you MUCH faster and cleaner results.
Keep saying this mantra: "Electrical crossover transfer functions are not the same as acoustic crossover transfer functions."
Old 15th May 2003, 02:57 PM   #10
Raka's Avatar
I strongly recommend the speakerworkshop, I think would be perfect for you.
Then, your task will be easier.
Active 3-ways with solen active loudspeaker module soundemon Multi-Way 14 19th March 2009 11:17 AM
Behringer DCX2496 I want to try active biamping using it as the active xover. georgehifi Digital Line Level 3 15th August 2006 07:46 AM
Hi-freq Active Crossover Needed HipoFutura Solid State 6 30th July 2006 08:22 PM
TL freq response bigwill Subwoofers 6 13th July 2005 07:02 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Copyright 1999-2017 diyAudio
