Hello,
Would like to get some pointers/information on how you choose the crossover order, whether it be 1st, 2nd, 3rd or 4th order for drivers. What factors determine the order you would use for a driver. |
#2 |
It's pretty much the driver choice that determines that.
#3 |
For one, if there are any breakup nodes in the response...you'd want a steeper slope to avoid those, depending on your Xover point.
Jim J. |
#4 |
yes, out of band response will determine how steeply you need to roll off,
and power handling is also a factor- why most tweeters use 2nd order or above. At the low end, if you're factoring in BSC, you may want to go for lower order slopes...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
| LR 4th order vs LR 8th order crossover | redliner | Subwoofers | 1 | 7th January 2009 11:32 PM |
| 1st order crossover design! | davidbosch | Multi-Way | 3 | 27th March 2008 10:02 AM |
| 1st order Passive Line Level Crossover + 2nd order Highpass? | alexclaber | Multi-Way | 11 | 4th January 2008 07:15 PM |
| first order crossover | svokke | Multi-Way | 15 | 8th April 2005 08:48 PM |
| Crossover - 1st Order | GeniX | Multi-Way | 3 | 20th September 2002 02:39 PM |
| Page generated in 0.12542 seconds (52.82% PHP - 47.18% MySQL) with 10 queries |
