Old 13th September 2009, 04:30 PM   #1
krips is offline krips  Canada
Default Ciare 6.38NdW
http://www.usspeaker.com/ciare%206.38ndw-1.htm
The FR looks a little ragged, but it appears to have super low inductance and pretty nice sensitivity. I'm looking to use it as a midrange in a 3-way. What're your opinions on this? Other suggestions for 90db w/m+ midranges <$200? Thx.
Old 13th September 2009, 07:11 PM   #2
B&C 6md38....95db....less than $90
Old 14th September 2009, 06:20 AM   #3
el`Ol is offline el`Ol  Germany
Eighteensound 6ND430, good tested at Zaphaudio.com.
Old 14th September 2009, 07:05 AM   #4
ermes is offline ermes  Greenland
hi,
i suggest you, forget ciare and try one of the two are been suggested.
bye
Old 15th September 2009, 02:06 AM   #5
D OB G is offline D OB G  Australia
The 6ND430 is used in the pro world for voice reinforcement i.e. chosen for its excellent intelligibility.
It is often used in a ported enclosure down to 60 Hz. i.e. good Xmax (+/- 5mm) and power handling.
In pro line arrays it is used up to 5 kHz (with a notch).
David
Has anyone tried the Ciare 8.50 NdMR or the Ciare 6.38 NdMR in a front horn? pk Multi-Way 6 10th January 2009 09:42 AM
Ciare PH250 sumacSK Full Range 6 15th December 2007 09:15 PM
Ciare 250 Nuuk Full Range 190 7th December 2005 03:55 AM
Ciare PW 455 Ruben Multi-Way 2 3rd December 2004 11:50 AM
Page generated in 0.12025 seconds (59.22% PHP - 40.78% MySQL) with 10 queries
