Old 13th September 2009, 02:04 PM   #1
jzagaja is offline jzagaja  Poland
Send a message via Skype™ to jzagaja
Default How do you coat your boxes?
I coat mine with two compound polyurethane (white enamel) but can't get smooth surface, an orange peel is a problem. Have tried HP 1.4 and HVLP 1.7 tips with different pressures. I know it is easier with automotive paints but they are expensive and my box is made of chipboard with polyester filler - not worth extra lacquers.
I would try soft-coatings like Alexit and Nextels from Mankiewicz.de but as you see I can't learn even simple spraying.
What's your experience guys?
Old 13th September 2009, 02:31 PM   #2
T in AZ is offline T in AZ  United States
orange peel = not enough reducer or thinner
Old 13th September 2009, 05:42 PM   #3
I'm reaching manufacturer maximum (20%). Isn't it simpler with acrylic urethane? Poly requires 12 hours between layers. I don't use oil compressor but have some water and just one fine grain filter before gun. Isn't it simpler with water base enamels?
Old 13th September 2009, 06:20 PM   #4
You are using a hardener ? I wouldn't worry about going a little higher with the reducer, test it out with a small test shoot. Poly should be wet sandable in 6-8hrs. Water enamels are softer and don't have depth.
Old 13th September 2009, 07:29 PM   #5
I'm using hardener (20%). Ok so here is my idea: 30% thinner, 1.4mm HP tip, 5 bar, wide flux and cross painting.
Old 13th September 2009, 08:03 PM   #6
Sounds good, I have gone higher with the reducer, but it gets a little tricky.
Old 14th September 2009, 06:40 AM   #7
Do you also sand your work? I'm so tired with hand sanding. Yato (former Toya) produces orbital random sander which consumes only 57 litres (2cfm) targeted to pro market.
Do coat hangers sound as good as Monster cables? Geek Everything Else 14 7th March 2008 10:46 AM
Is it ok to coat the cone AND surround with laquer? GuyPanico Multi-Way 2 6th December 2005 10:02 AM
Is there a colored equivalent to puzzle coat/modpodge? GuyPanico Multi-Way 3 30th May 2005 06:57 PM
new boxes GringoAudio Multi-Way 2 18th August 2004 03:50 AM
aleph 2-thermistor coat cracked marijan Pass Labs 8 2nd September 2002 07:29 PM
Page generated in 0.10137 seconds (62.42% PHP - 37.58% MySQL) with 10 queries
