#1 | |
#2 |
The question is, what can you stand listening to it
I doubt you'll need anywhere near the rated power to get ear-bleedingly loud. A cool thing about compression drivers
Jim J. |
#3 |
Yes, u r right.
I want to know how to calculate the watts according to frequency for a given specification. This is from academic interest. I am not going to use this compression driver. But the principle can be applied to other low wattage drivers also. |
#4 |
Proud Union Member
Dude, being very familiar with the 24** family of drivers- You really don't want to put 150W into one. Least, not be in the room when you do.
#5 | |
Put too much power into a driver and it melts. Put too much power at a low frequency into a driver, and the motor throws the cone on the floor. Interpreting the spec, below 1K, the driver is excursion limited. Above, its thermal limited. In other words, 150 W at 1K or Higher. HTH Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well) Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus |
#6 |
I am Sorry to repeat.
I don't want to use jbl driver. I just want to know calculation of how the power watts changes with frequency. Here is another driver example. This is Paudio WN D44. Here also they hv given different power watts at different frequency. |
#7 |
There isn't really a neat calculation for it, it's based on the design of the motor. Some drivers are more resistant to mechanical damage than others.
Jim J. |
#8 | |
This is "Continuous program" rating. From JBL spec sheets:
http://en.wikipedia.org/wiki/Pink_noise |
#9 | |
Instead it is a lot of limiting factors that can destroy a driver, and at different frequencies then different factors will be the factor that sets the limit. For instance: At lower frequencies it will usually be damaged by overexcurssion, but at higher frequencies where excursion is lower then the heat dissipation will be the limiting factor. However, it is a lot more complicated than that... The JBL driver mentioned earlier is usually crossed over at about 1.4KHz and driven with over 1000watt, and it will hold for decades with that amplifier. Why? because music is usually very short bursts of power that doesnt heat the motor enough to burn it, but also with a lot of time inbetween bursts to allow the heat to travel out of the driver... -It is not the power that destorys the driver, it is the temperature... An another thing to consider is that impedance changes with frequency, so you need different amplifiers to put the same amount of power thru the driver at different frequencies. So, the only reliable way to see what power it will handle is to make a model of every single detail in the driver *and horn* and then calculate all the limiting factors to see which one that will break first for each frequency. |
#10 |
Thanks electroaudio & pos.
This means that it is not easy calculation. |
| Coaxial Compression driver | hugobors | Multi-Way | 5 | 27th September 2011 05:21 PM |
| Zen and Compression Driver | Opus Pocus | Pass Labs | 3 | 10th September 2008 10:02 PM |
| ESL as a compression driver? | tade | Planars & Exotics | 32 | 16th August 2007 11:30 PM |
| FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) | theAnonymous1 | Swap Meet | 0 | 24th April 2007 12:09 AM |
| Page generated in 0.13617 seconds (72.59% PHP - 27.41% MySQL) with 11 queries |
